Question about D-Link AirPlus DI-524 Wireless Router
How do I disable the wireless connection in DI-524 ?
How do I disable the wireless connection in DI-524 while keeping the routing only in the wire connection?
Thanks,
Gidi
  • Anonymous Apr 06, 2009
    Thanks,
    Yossi
I forgot the password of my 11g router and i resetted it and now i m not able to acces its configuration page no matter what i have tried the ips 192.168.1.1 and 192.168.1.2 192.168.0.1 and many more but it just wont show so what should be done
Posted on Dec 24, 2008
  • desadahlia Dec 24, 2008
    i forgot the password of my 11g router 3com 3crwdr101a-75 and i resetted it and now i m not able to acces its configuration page no matter what i have tried the ips 192.168.1.1 and 192.168.1.2 192.168.0.1 and many more but it just wont show so what should be done
I want to disable wirless broadcasting in D-Link DI-524 how i can do it ?
I don't think you can disable the wireless but you can prevent people accessing your wireless network.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Alternately you can connect your computer to your DSL or cable modem without using the D-Link.
Dec 20, 2010 | D-Link AirPlus DI-524 Wireless Router
DI-524 wired/wireless access point
Just for fun, make the router give out IP addresses starting at 192.168.0.101 forward. Configure the AP at 192.168.0.2 with no DHCP (the host will give out the addresses), a netmask of 255.255.255.0, and a gateway of 192.168.0.1. Now, let the laptop find DHCP, or give it a 192.168.0.x address where x is greater than 2 but less than 101.
How lucky is that?
Carl
Nov 19, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
DI-524 does not maintain connection
Some ISPs are cutting connection after a set period of idle time to conserve users per router ratio. There are programs to "keep alive" connections (some router have this ability built-in also).
Feb 05, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect DI-524 to VISTA
There is nothing on DI-524 what is Vista specific. Make sure you installed your dirivers properly. I have the same , works without problems.
Jan 22, 2009 | D-Link DI-624 Air Plus XtremeG Wireless...
How do I lock my modem?
Go to a computer wired to your router
Open an internet explorer browser
Click on the address bar and type in 192.168.0.1
Type your password for the router.
Normally be default its username admin and blank for password.
Go to wireless on the left side.
Under security type in WPA-PSK
Type in a password 8 charachters or more
ON your wireless computer
Connect to your network name and put in that 8 char password.
If there is anything else just message
Sep 03, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 Wireless
Yes you can, it's easy.
1. Just connect one of the LAN ports of the DI-524 to a LAN port of your other router. Leave the DI-524 WAN port empty.
2. Disable the DHCP server on your DI-524, your other router will be the DHCP server.
3. Assign a static IP address to you DI-524, different from your other router's. Example, if your other router has 192.168.2.1, you may assign 192.168.2.4. Make sure that the IP address you assign is outside the DHCP range configured in your other router and that the subnet mask is identical on both.
Feb 20, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
807 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
