Question about Sony VAIO Digital Studio PCV-RX670 PC Desktop
WINDOWS - NO DISK ERROR
HELLO, I GETTING THIS PROBLEM & I DNT KNOW HOW TO FIX IT ...AS SOON AS I START MY PC, THIS ERROR POPS UP...
ANY IDEAS TO SOLVE THIS PROBLEM...
  • Jarish Castaneda
    Jarish Castaneda May 11, 2010
    What error message comes up when booting your computer?
    Master:
  • 413 Answers
FIrst make sure there are no non-bootable disks or thumb drives in the computer. Then get into bios and check the boot sequence and make sure all drives are enabled.
Posted on Dec 24, 2008
Error on startup when trying to open a file
I receive the same error, but only when opening or saving a file while a removable drive is attached to the computer (typically my camera's CF card). Naturally this is annoying when processing new photos. I don't have a solution to the underlying problem, but I do have a workaround for the annoying pop-up message. It involves using Windows Registry Editor, so use at your own risk.
1. Start Button -> Run
2. Type "regedit" without the quotes
3. Proceed through the following entries (double-click each name:
HKEY_LOCAL_MACHINE -> SYSTEM -> CurrentControlSet ->
Control -> Windows
4. Locate "ErrorMode" and double-click
5. Change the entry for "Value Data" from 0 to 2
6. Change the entry for "Base" from Hexadecimal to Decimal
7. Click "OK"
8. Press F5 to refresh the Registry Editor
9. Close all windows and restart your computer
Again, this will stop the pop-up messages warning you that there's no disk, but it doesn't solve the underlying problem. If you're comfortable that there's nothing actually wrong with your computer (I am) this will at least make GIMP usable again. Thanks to jamuma on answers.microsoft.com for the original idea.
Aug 15, 2012 | GIMP GNU Image Manipulation Program
I switch on my pc (window xp) this evening, and my pc auto restart with blue screen pop out. its say some error with name 'fatal system error'. already clean disk, de-fragment in the safe mo
turn on computer,press F* repetedly until screen shows up wth options
safe mode
safe mode with networking etc...
in dat screen select option "most recent good configuration"
and enter..next window select windows xp and enter..thats it.
after u log in.clean whole system with good virus scanner for viruses,malware,trojans all
May 19, 2012 | Computers & Internet
Hello i went to restore my acer and now it's stuck when i turn it on first you see acer screen then it goes to starting acer recovery management then windows xp screen and then it says please wait then it...
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Dec 20, 2010 | Acer Aspire One AOA150-1635 Notebook
Need help please and thank you
For that you need to fix error on harddrive.
For that You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 05, 2010 | Compaq Presario 5000 PC Desktop
When starting my computer windows wont let it load because it says there is a problem with a program or drive on a blue screen just after the windows xp logo appears(on screen half time normally is) i've...
Start your computer in safe mode (press F8 before you get the Windows splash screen). I usually suggest pressing F8 continuously as soon as you see anything on the screen.
Once you get the white menu up that allows you to enter safe mode, let the computer boot into safe mode and do a system restore back to when you know the system worked.
That should solve the problem.
Jan 16, 2010 | Dell Computers & Internet
Error loading c: progra 1/mywebs 1/bar m3 dll
Morning,
1.Click on Start,Run
2.Type msconfig, click ok.
3. Go to the strartup tab at the top of the window that opened.
4. Look for a startup entry, that is linked to your problem, go through all of them carefully and remove the tic mark in the check box,
5. Restart your PC
6 After the restart, a grey block will popup saying that you've made changes .....
7. Tic the checkbox that says,"do not show this message again"
Problem Solved, if it still pops up ,let me know
Cheers
May 26, 2009 | Microsoft Windows XP Professional
PC not booting!
please chat with me so that we can solve your problem in a better way...........thank
Thanks and Regards
Dilip Bagdi
Technical Associate
May 07, 2008 | Computers & Internet
Windows error message-
That seems like it's a problem with a malware or virus being present, as it's making windows think there is no system disk.
Check this site:  http://www.consumingexperience.com/2007/11/windows-no-disk-exception-processing.html
It will explain how to fix the issue.
May 01, 2008 | HP PAVILION A6230N DESKTOP PC
Sony VAIO Digital Studio PCV-RX670 PC Desktop Logo
65 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
