Question about ASUS M2N-MX Motherboard
After restart motherboard beep 3 times
I have a Asus M2N-E and a few weeks ago after I booted the system up and loged on to windows and the monitor started to to go on and off thinking at was the the video card I bought a nvidia geForce 9400 gt 1gb ddr2 1x dvi + x vga after installing it and booting it up it worked fine but after restarting the system it started to beep 3 times. after turning the switch off and wait 5 minuts the system boots up fine but if I restart the same problem repeats. I brought it to a technition and he told me that it was the video card but i told him that the card was new and when it does start, the system works with no isues. Please help because I have checked ram evrything exepct the power adapter.
Is at possible that theres not enough power to bootup the card?
  • bryck Dec 27, 2008
    I replaced the old one with the 9400 but what I found weird is that for th past 2 days the system worked fine, this morning I started it up and the same problem was happening. anyways thanx for the help Merry christmas to u too and a happy New Year.
  • 70 Answers
With the award bios 3 beeps usally indicates the video adapter (1long beep 2 short beeps) So one question for clarifcation.
Did you replace an older vid card that was having this problem with the 9400 or was the 9400 card the only card in this system?
If the 9400 was the only card ever in the system I would say RMA the card. It is very possible for a new card to be defective. If you where having the same issues with an differnt card as well You Should goto and update your bios to the latest version.
If you still have a problem after updating the bios then I would RMA the motherboard.
Hope this helps and let me know how this turns out.
Merry christmas:
Posted on Dec 24, 2008
My system is also making a beep sound while booting up?( the time period of beep sound is time take to read beep)i think 1 sec What might be the problem.. Even after scanning entire system and deleting the...
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
the grrr is the sound its not getting enough power
test your PSU power supply unit or replace it if the fan is not working the PSU is faulty
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Feb 01, 2011 | ASUS M2N-MX Motherboard
No beeps or monitor signal
Sure, a motherboard can be a dud out of the box like any other part. If you have a known good power supply, processor and memory installed, and the machine doesn't boot and you have no video, the only thing left is a non-working motherboard. Return it to the vendor and get it exchanged as defective.
Jun 20, 2009 | ASUS M2N-VM DVI - Motherboard - micro ATX...
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
The flash memory don't work in windows vista please help me if ther is any new driver for this
Hello mohamadg, you need to clarify your question. Flash memory looks like the memory shown on the site below; (Click on the link).
(I think your question pertains to system memory)!
System memory for the Asus motherboard looks like this;
Your Asus motherboard can only function with, DDR2-800MHz / 667MHz or 533Mhz (Only). Dual channel 4x240 non-ecc memory. You can run up to 8 GB max of memory. If the system memory you are currently using does not match the above type & speed, your motherboard will not function. You will hear a series of beeps during start up of the system. These beeps are known as bios beeps. How many beeps (Including long beeps & how many short beeps you might hear) will tell you what is most likely wrong with your system memory. (See the next link for the Award bios beep codes);
Dual channel memory should be bought in pairs & not as a single stick/DIMM. Do not install more than 2GB of system memory until windows has been completely updated through (Windows Update Services). Once Vista or any version of windows has been fully updated you can increase your system memory. You can not mix memory speeds & type. If you are using 533MHz memory, & you want to increase the total memory to be used, you must match the memory speed of 533MHz. All system memory must be the same speed & type. See page 2-10 in your manual. Running two different types of memory may not give off bios beeps & the system may not function at all.
For drivers, click on the Asus link;
Once the link opends, type the model number M2N-E SLI into the search window located in the upper right hand corner of the link & than click the white arrow. In the next link that opends click on, "M2N-E SLI related files for download". Another window will open. Click on the dropdown menu & choose your operating system & click search.
All drivers, manual, bios files, bios utility, CPU supported & FAQ's are listed there.
FAQ link for Vista;
This last link shows the memory tested to work with the M2N-E SLI (Green) motherboard;
If this has not answered your question, please let me know.
Thank you for using FixYa mohamadg!
Feb 13, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Computer continusly restarts after windows logo shows up
You probably can try reinstalling windows or check your boot order again
Dec 18, 2008 | ASUS M2N-MX Motherboard
Asus |M2N-E SLI Reeboot issues
Hey, I own the same motherboard and I don't have your problem.
I would suggest trying to update the bios, i think its more of a bios problem / motherboard issue, not windows related.
you can get the newest bios from
Oct 20, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
NO video @ bootup
Are you sure that the memory you have installed is compatible with your motherboard.
It is weired but some memory do not work with certain motherboards, irespective of speed or voltage rating.
Aug 05, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
My Computer does not boot
please check whre u have connected ur monitor comm cable, is it in agp card or on borad display card
Apr 21, 2008 | ASUS M2N-MX Motherboard
M2N-MX SE Will Samtron 55V work?
Does not matter the monitor, has to work , probably u test it on a resolution or frecvency that u're display does not support, try to enter safe mode (for windows) by pressing F8 on boot up , and chose than safe mode, or VGA compatible mode, should work! Change the resolution/freqvency to one that u're display supports
If u have more than one video adapters (one onbord) try to see whitch one is enabled....
Jan 16, 2008 | ASUS M2N-MX Motherboard
ASUS M2N-MX Motherboard Logo
186 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
