Question about New World Spirit 110 (Gas) Kitchen Range
Problem with gas double oven
Our double gas oven(new world image 1000 mk 2}seems to have an ignitor problem. when you light up one plate you can hear the ignitor coming on at another plate which you are not wanting to come on. does this make sense?? could you assist me please.. roddy
    President:
  • 1,462 Answers
Im in uk not us so don't know this particular appliance. however many gas appliances turn on the ignitors for other parts than the one required - ie if one burner on a hob is lit, the other ignitors spark as well. suspect you don't really have a fault
Posted on Apr 16, 2007
The ignition continues after gas lights on new world elegance/cooker and grill
The igniter will glow orange while the oven is on. This is NORMAL. If it went out the burner would not come back on when the thermostat calls for heat .
Aug 18, 2014 | New World G90m Gas Double Oven
Gas wont stay lit after ignition
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 19, 2011 | New World G60m Gas Single Oven
Mad gas flame at back of New World G70M
HI it could be agas pressure problem meter pressure too high get the gas company to check it out for you
Feb 04, 2010 | New World G70m Gas Double Oven
Oven wont light unless you turn on a stove eye and
Sound`s to me you need a new hot surface ignitor. Sorry to hear you may have changed the valve & regulator for nothing, but that happen`s quite often when you get the symptom`s you`ve described, I`ve even seen tech`s. do it. The reality is 9 times out of 10 when a hot surface ignition gas/lpg oven won`t light it is the ignitor.
Pick up part number 74007498 for approx. $40 and you`ll be cooking.
Hope that help`s. If so please take a second and rate the solution I provided here at fixya for you.
Good luck.
macmarkus :)
Dec 05, 2009 | Maytag Kitchen Ranges
Model fgf334bgwj gas range oven will not operate. I removed the oven bottom plate and deflection plate , the glow bar turns on but no gas flows to ignitor? Is it the gas safety valve?
When the ignitor glows brightly and the oven doesn't light it is usually a defective ignitor. The way to know if the ignitor is good or bad is to read the amp draw of the ignitor with an amp or watt meter. The gas valve and the ignitor are wired in series and for the gas valve to draw the current the ignitor has to draw 3.5-3.8 amps.If the ignitor is drawing 3.5-3.8 amps the new gas valve is defective. If it is drawing less amps the ignitor is defective.
Jan 25, 2009 | Kitchen Ranges
Gas isn't coming on for "Bake"
First the ignitor must glow very bright / compare the broiler ignitor to the bake on... the ignitor must pull 3.6 amps to open the gas valve... so even if it does glow it must glow bright and evenly to pull the 3.6 amp... you can test it if you have an AMP meter...
Gas valve do fail but it is rare... it is most likely a weak ignitor... hope it help please let me know...
Sep 13, 2008 | Frigidaire FGF355 Gas Kitchen Range
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Ignitor problem?
if you remove the 2 screws on the right and left bottom plate and open the door and youll see 2 screws that panel will come off turn the oven on and you should see 2 burners on both sides and they should ignite.if they do and go right out you could have 2 problems.when the burners light they hit a probe called a flame sense.this probe plugs into a heat board and if the board doesnt sense the flame you will get a red no ignition light.clean the probes that sit right on the burners with sandpaper and see what happens,if that doesnt work if the unit has pilots clean the pilot orfice and if that doesnt work the heat board may be bad.how old is the unit?
Feb 25, 2007 | Vulcan VC44GD Gas Double Oven
GE XL44 gas oven
Starfish, remove the oven racks, in back there will be two chrome screws, remove them. Lift the lower oven panel out by pulling up from the rear. Remove the screws holding the flame spreader and remove the flame spreader. Now you will see the burner and igniter attached to it. There are 2 quarter inch hex screws holding the ignitor on. GE likes to put them on an angle where you cant get at them. If you have trouble you can remove the bottom drawer and remove the screws securing the burner to the back wall. There should be one in the front too. The burner will now lift up and you can get at the screws. The new ignitor should come with ceramic wire nuts. Just cut the old igniter, strip the ends of the wires going to it and wire nut the new one on. Reverse the rest of the steps. Here's a little trouble shooting schem. Catriver...post back.
Jan 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
My range pilots work fine but my oven pilot will not light. Do pilots wear out after 4 years? Is it easy to replace a pilot?
Trey, this is not a hard fix. More than likley your ignitor for the oven has gone bad. It has to draw a certain amount of amps to open the gas valve. If you remove the bottom panel in the oven, should be 2 screws in the back and lift it out, you will see the flame spreader. Remove this, should be a couple 1/4 inch screws. Now you will be looking at the burner and ignitor. The part number for the ignitor is wb13k0021. The ignitor is held on to the burner with 2 1/4 inch screws. It is not uncommon for these ignitors to fail within 4 years....Catriver...post back.
Jul 29, 2006 | GE JGBS07PEAWW Gas Kitchen Range
New World Spirit 110 (Gas) Kitchen Range Logo
284 people viewed this question
Top New World Kitchen Ranges Experts
ashburton
Ismael Rodriguez...
Paul Carew
Are you a New World Kitchen Range Expert? Answer questions, earn points and help others
