Question about IBM eServer xSeries 346 8840 (884022U)
Red led on pannel of XSERIES 346 8840-11Y IBM server
Dear support team,
on the very right pannel there is a red led .
Do I have serious prob?
What does ut mean?
I took photo of it (can I send)?
Thanks and best regards
Rachel
  • Jordan Bracho Jul 31, 2012
    right now my server has the same problem, has a red light on the exclamation symbol on the front panel, is working smoothly and I rebooted and it has no problems. Any suggestion about it will be accepted. thanks
Check your event viewer.In that Check if any error messages is present for system,Application,Security.
Posted on Sep 10, 2009
I need to know where the red light is? email wwrics@verizon.net and what the server is doing as to booting or running. I am a hardware tech and can assit with hardware issues. wwrics
Posted on Feb 27, 2009
Install Windows 2012 on IBM xSeries 346 server
check from the manufacturer which operating systems are compatible with your server
Mar 31, 2014 | IBM xSeries 346 Server
IBM eServer XSeries 235 no DC power light
This would be SMPS issue. Replace it
Thanks
Sep 13, 2012 | IBM eServer xSeries 235 (867131xj)
Problems with IBM Xseries 346 Server
Check Light Path Diagnostic which is located on the front side of server . It gives a clue of what's the issue . If you can't see any amber on Light Path Diagnostic , then its an indication of max logs logged on BIOS event logs. You may need to restart server > Get into Bios and clear all event logs . This would remove the information sympol from server .
Jul 31, 2012 | IBM xSeries 346 Server
How we identify ram sequence x226
Welcome to just answer
There is no ram sequence for IBM 226 server . But you can identify the problem by checking the orange led on the specific ram . Each ram slot has amber (orange) led . The slot that gives the amber has the issue .
Hope you understood
Thanks
Feb 09, 2011 | IBM xSeries 226 Server
IBM xseries eserver x236 Bios problem: a yellow light( !) like this is on and IBM server can not start
Try this:
Light path diagnostics
Many errors are first indicated by the illumination of the system-error light in the operator information panel on the front of the server. One or more lights inside the server might also be lit that can direct you to the source of the error. The system information LED lights to alert you that there might be important information recorded in the system-error log. 2. Removing the left-side cover and look at the light panel. These LEDs indicate the type of error that has occurred.3. Once you know the general type of error and the general location of the component involved, the next step is to check the system service label on the outside of the server. This label gives an overview of internal components that correspond to many of the LEDs on the light path diagnostics panel and can help to view lit LEDs inside the server. Note: Some of the LEDs on the light path diagnostics panel will not have a corresponding LED lit on the system board.
Good Luck
C2Solutions
Dec 31, 2010 | IBM eServer xSeries 236
IBM xSeries 360 Server support Win 2003?
The good news is IBM says it will work, the BIOS might require an upgrade. I would consult ibm.com and get the latest updates for your hardware after that insert CD and reboot!
Have Fun.
Jul 23, 2009 | IBM xSeries 360 Server
Ibm server xseries 326
It is not detecting the HDD because the windows install does not have the necessary drivers. On the windwos install you must press F6 or F2 I don't remember which one but it prompts you for them to load external drivers fro SCSI or other type of drives, you must download the right drivers for the type of HDD the server has probably fromt eh IBM support website, put them in a floppy and load them from the floppy into the windows install so it recognizes the drives..
Jun 02, 2009 | IBM eserver xSeries 360 8686
SCSI hard disk is not detecting in IBM xSeries 346 Server
Hi
While running the windows 2003 setup (winnt.exe), it will ask for SASI driver, you have to add the scsi driver... then windows 2003 os will detect the HDD.. then it will install..
Apr 07, 2009 | IBM eServer xSeries 346
How do i get a IBM Xseries server to recognize a serverraid card
IBM Serverguide will most likely get you going again. Go this link:
http://www-947.ibm.com/systems/support/supportsite.wss/docdisplay?lndocid=SERV-GUIDE&brandind=5000008. You can download the ISO image for the version of Serverguide that will let you configure your system. If you have a Xseries 360 version 7.2.03 should work.
I hope this helps. Good luck!
-jodair
Apr 03, 2009 | IBM eserver xSeries 360 8686
IBM xseries 205, Model 8480-43X Memory upgrade an POST BEEP
Those beeps mean that your RAM is not functioning. Are you sure you got the right upgrade type. Sometimes it'll fit into socket but won't work because of speed. Or just try reseating the modules.
Jan 14, 2009 | IBM eserver xSeries 205 8480
IBM eServer xSeries 346 8840 (884022U) Logo
1,417 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
