Question about Transcend (589307) Media
Usb not recognised
If i connect my usb flash drive to the computer, it says windows not recognise usb drive due to malfunction. but it was working good earlier. now what is the problem in my computer?
  • 183 Answers
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Posted on Dec 24, 2008
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
USB DEVICE NOT RECOGNISED: One of the USB device attached to this computer has malfunctioned and windows does not recognised it.
The problem you have stated can be due to several causes. Please eject your USB drive from your computer and insert it again. If windows does not detect it, then restart your computer and try again. If the problem is still there, please check the Device Manager if the USB port is properly working and if it is possible to use the troubleshoot. The best way to check whether your USB device is properly working or not, insert it to another computer other than your's. If the problem persists, check your USB device's warranty period and simply go for the replacement and contact your retailer or service provider.
You can go to Device Manger by following the steps below:
My Computer Icon>Right Click on the Icon>Properties>Device Manager
Thanks for using FixYa.
Hope this helps,
Apr 03, 2011 | Computers & Internet
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
Usb device not recognised.
install the driver for it
search it from
"can u please rate me free.... for my hint"
thanks in advance
May 17, 2009 | Transcend (589307) Media
My usb flash drive is working but my computer not recognising
Check for viruses your USB .If it is allright.
Check your USB Stroge drivers .Are they installed.?
Dec 24, 2008 | Transcend (589307) Media
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Problem with USB Flash
It is possible the memory stick is faulty. Are you using xp or vista? If so it should be recognised instantly. I bought one the same a couple of weeks ago, and it recognised it instantly, and I'm using xp.
Try it on another computer if possible, even where you purchased it. Just tell them you think it's faulty. If it works on that computer then you have a problem with either your usb ports or you have a virus.
Jan 01, 2008 | Electronics - Others
Transcend (589307) Media Logo
195 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
