Question about Transcend (589307) Media
My usb flash drive is working but my computer not recognising
My usb flash drive is working in other computers but in in my computer, it is not recognised due to malfunction
  • Agnirudra Jan 12, 2009
    n what if i am not able detect the drive m i supposed to scan it?
Check for viruses your USB .If it is allright.
Check your USB Stroge drivers .Are they installed.?
Posted on Dec 24, 2008
Jonathan deleted my usb
Several conditions affect how the USB device functions. First, unplugging the USB device least with the prescribed method of shutting resources with the menu buttons provided on computer makes device loose components recognisable at replugin. usually, in such instance the computer takes time to reconfigure the device at reconnection either automatically installing mutated codes or requesting to manually download the fragmented codes. Second, computer that have undergone updates or upgrades prior to establishing the USB devices least recognies the device. Reconnect the device to momentarily reconfigure the new setting attained on computer. Depending on the type of modifications that were made to the computer would either autocompile the USB codes to attain functionality or require manual installation of missing programs. usually the computer has the recommended missing programs only requires unpacking at the system update search buttons. In the sitaution where the computer was modified beyond recognising USB device require to ascertian that compartible ssytems would allow install a program from elswhere or simple acquiring another computer thar recognises the USB device.
Feb 16, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My flash drive is not recognised by the computer pls help can recover data from most damaged and faulty flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 30, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
When I plug in my Usb into the computer, it doesn't recognise
Apr 09, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Xp computer wont recognise new 250gb elements ext hard drive
use it on a differnet usb port
these portable hard drives have some issues with 1.1 usb ports
Jul 12, 2009 | Computers & Internet
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
Verbatim 4gb flash cant be recognised
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Jun 02, 2009 | Verbatim CORPORATION 94933 USB 2.1GB...
Usb not recognised
Hello ak1979 ...
1. You're plugging in your Transend USB flash drive to your computer's USB port (as you've done many times successfully before with this SAME flash drive)?
2. It says "windows not recognise usb drive due to malfunction"?
a. Is that EXECTLY what the error says?
b. Is "it" an error dialog (window that pops up), or an error message from your Windows Event error logs? If a dialog, are there any pertinent error message entries in your Windows Event (System) log [Start > Run > type "eventvwr.msc" (without quotes), then "OK"]?
Try a bit of deductive troubleshooting:
  1. Restart (Reboot) your system [for a fresh start, if you will].
  2. Try plugging in your USB flash drive again, but in a DIFFERENT USB port.
  3. Try plugging in ANY OTHER "known good" USB device into the same USB port(s) used thus far that failed.
NOTE: If you EVER get any indication Windows recognizes the flash drive (like no error msg, or it shows in "My Computer"), IMMEDIATELY perform a "Check Disk" on it:
  1. Start > Run... > type "cmd" (without quotes), then "OK".
  2. Type "chkdsk DRIVE_LTR: /f" (without quotes), then hit "Enter" [where DRIVE_LTR is the drive letter of your USB drive]. EXAMPLE: chkdsk E: /f
Good luck, and please post back:
  • to provide any corrections/updates/clarifications.
  • if you have any further questions.
  • to let me know how things work out.
"Today's the best day of my life...and NOW you're part of it!"
Dec 24, 2008 | Transcend (589307) Media
Im plugging my flash drive into the usb and nothing is coming up. this one works in other computers but not this one
For starters, what is the operating system of this computer?
Windows XP will recognise flash drives, 2000 seems to recognise some but if you have 95, 98 or Me you need to install a driver for the drive. The manufacturer of the drive may not even supply one.
Sep 28, 2008 | Computers & Internet
Computer won't recognise camera to download images
** Problem Solved **
I found it wasn't the camera entirely to blame. I tried another USB cable on another pc, and although the camera was doing the same thing as my problem, the computer recognised the camera as new hardware, and asked me how to access the pictures. So I was able to get the pictures from the camera to the computer, and then saved them on to my Kingston flash drive. So taking the flash drive to my daily PC, I plugged in my flash drive via a USB extension lead, and discovered that would read either... alarm bells rang. So I unplugged the lead, and put the flash drive straight into the computer direct. The computer recognised it immediately. So plugging in the extension lead again, and the flash drive, it read this now. So I tried the camera, and it recognised it.
So I don't know exactly what the problem was, but it was solved... saved me a lot of running around and money ;)
Feb 13, 2008 | Cameras
Transcend (589307) Media Logo
79 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
