Question about Panasonic Lumix DMC-LZ2 Digital Camera
Internal lens Cover
My internal lens cover stopped opening, is there a fix, or can it be removed safely ?
  • Panasonic Master
  • 4,738 Answers
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Posted on Nov 25, 2007
    Genius:
  • 2,985 Answers
No fix -Panasonic may help on the customer support line
Posted on Aug 02, 2007
Somewhere in the past aright handed lens cover has become lost. Need another.
Not sure about the reference to 'right-handed' lens cover - most of them have a spring clip for the filter threads. To get a lens cap, just look on eBay for one that has the same internal diameter as the filter threads on the lens - this is usually marked on the lens, as in 49mm, 52mm etc.
Oct 20, 2017 | Cameras
Drive belt came off internal spool. How do I remove cover to fix
Press tabs within four corners of the scanner and careful remove the top of the glass scanner
Jun 22, 2014 | Epson Perfection 3170 Flatbed Scanner
My dimension 3100 is not detecting a modem
Sir,
Respectfully please first check if there is a modem in the desktop PC since the dimension 3100 is not pre-equipped with a modem. you have to attach an internal modem manually on one or more PCI slots on the mother board.
the process is given here....
  • Turn off the computer. Unplug the power cord from the electrical outlet. Disconnect the power cord, attached peripheral devices and any other cables.
  • 2 Locate the cover release latch on top of the computer, near the back. Place the computer on its side, with the removable cover facing upwards. Slide the cover release latch back and lift the removable cover off of the computer. Set the removable cover aside.
  • Locate the PCI and PCI Express slots near the bottom of the system board. Select a slot that corresponds with your internal modem card. Open the card retention door on the back of the computer and remove the filler bracket for the card slot you will be using.
  • 4 Place the internal modem card into the appropriate card slot and press it firmly into place. Close the card retention door. Replace the removable cover and return the computer to an upright position.
  • 5 Connect one end of the telephone cord into the LINE port on your internal modem card; plug the remaining end into a telephone jack. If desired, connect a telephone to the internal modem card via the PHONE port.
  • 6 Reconnect the power cord and all previously disconnected cables. Plug the power cord into an available electrical outlet. Turn on the computer. If any installation software came packaged with the internal modem card, run the program and follow the onscreen directions. Your internal modem is now ready for use.
  • May 06, 2011 | Dell Dimension 3100 PC Desktop
    Sony ericcson c905 ,open lens cover message displayed,when cover is actually open?
    DUE TO THE WRONG CONTACT CONNECTION IN LENS COVER AND THE INTERNAL BOARD.THERE MAY BE SHORT CIRCUIT.SO TRY TO CHANGE THE CASE.VOTE ME
    Sep 25, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
    Sony HDR-XR200 lens cover problem
    You have two options, replace the motor that opens and closes the lens cover or remove the lens cover shutters all together, and use a 30mm lens cap.
    May 25, 2010 | Sony HDR-XR200V High Definition AVCHD...
    Lens cover will not open
    easy fix. yo turn it on and then very lightly tap the lens cover or push it out. then you should clean the lens because the dirt or dust on the lens is stopping the lens cover.
    Aug 24, 2009 | Canon PowerShot A530 Digital Camera
    Lens cover won't close and there is internal dust
    A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Gently slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
    You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty):
    Apr 16, 2009 | Canon PowerShot A560 Digital Camera
    Canon digital IXUS 60. Lens does not move in and out. Camera turns on but nothing happens. Unable to take photographs. Error message:- Lens error restart camera. Restarting camera does not resolve problem
    I'm guessing that the lens is stuck. Either the cover refuses to open because something is wedged in or a mechanical malfunction. The camera won't work if the lens does not come out a bit. Take a look at the lens and examine why the cover doesn't open up. If it is a mechanical malfunction (meaning internal problem), might as well have it fixed. Be careful and keep your fingers off the lens. You may touch the cover but hands off the lens. Hope this helps.
    Jul 17, 2008 | Cameras
    Lens Cover Won't Open
    NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
    Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
    Lens cover will not full open up help needed
    Mine wont open at all. You can hear the lens trying to push it's way out but the cover doesnt move.
    Dec 27, 2007 | Olympus Stylus 800 / ? 800 Digital Camera
    Panasonic Lumix DMC-LZ2 Digital Camera Logo
    275 people viewed this question
    Top Panasonic Cameras Experts
    Computer Links
    Are you a Panasonic Camera Expert? Answer questions, earn points and help others
