Question about Onkyo TX-NR801 Receiver
Configuring the componet out ?
Hi, have plugged in componet cables into Componet Out on the Onkyo but I have no o/p on the TV. I used the av video cable to use the set up program and this worked. I know that our PAL model can't use the set up on component so I used the AV. I purchased a HDMI - component adapter. This has power on it and the TV recognises the cables but no O/P? Is there a set up I'm missing on the Onkyo ??
Thank You for your help MH.
  • mhindmarsh Dec 27, 2008
    Thank you,
    I purchased a converter but there is no o/p to the component of the receiver. I know the o/p  is across both the monitor out the s video and the video out puts. But I can't seem to make the component out put work and have a out put to the converter box.
    I hope this isn't to confusing but I can't work this one out.
    Thanks MH.
    Genius:
  • 1,011 Answers
U can buy a converter for output to configuring the tv. the converter is to connect the cables output to the player.
Posted on Dec 24, 2008
  • Asfiya Ahamed
    Asfiya Ahamed Dec 27, 2008
    Check the converter manual for configuring the converter. Because u have different cables to get output from the converter. the cable itself have separate outputs and lines....
I have a toshiba rear projection tv 40inch model no 40pw13p, does anyone know how i connect the xbox 360 as i cant get any av channels up?
Hello:The xbox came with an audio and video cable, probably componet cables on one end, if you are going to use HDTV input which is the red/grn/blue cables on the end of you xbox plug them into the corresponding color in the back of the tv, also on your cable is a switch labeled HTDT and TV make sure the switch is in the HDTV mode if you are going to connect the componet cables if you are going to use regular video then make sure its in the other posistion. If you use componet cables you are going to use the red an white audio cables also a total of five cables should be connected to the TV. Some newer xboxs have hdmi output as well this is the better of the three connections as it also has audio and hd all on one cable. using your tv's remote switch the tv's input to the same input you connected your xbox to. HAPPY GAMING..
Sep 29, 2011 | Televison & Video
My sony BDP-s550 has a green tint to all dvds we watch. I already tried resetting to the factory settings with no success.
Just another thing to check that may take a few seconds.. Are you using componet video cables on this dvd player? If you are, check that all 3 video cables are plugged in, you may even want to unplug the cables and plug them back in. If you have a spare componet cable try that as well to make sure it is not a cable issue. I have been to many homes where just 1 of the 3 componet cables was just unseated or had a broken cable.
Mar 08, 2011 | Sony BDP-S550 Blu-Ray Player
COMPONENT-AV CABLE FOR wii the colours are wrong please have you got a fitting instruction
OK this is simple just turn your tv turn on the lamp and look for the rite colors for the componet av cable and plug it in there u go!
Jun 26, 2010 | Video Game Consoles & Games
CONNECT TV,DVD, AND CABLE TOGETHER TO OPTIMIZE THE SOUND QUALITY .
Usually you have to use a couple of external AV Inputs. for the DVD and the Cable goes into the Componet/SVHS input, OR IF TV has a "Cable" "Antenna" socket, an "F" Connector (Female) You can hook up that way and "Tune" your cable channels. Now If you connect up to the Video in, on TV, you must also use corresponding Audio Channel as well. See ir depends on, how many and what sort of inputs you have. But usually you have a couple of AV inputs selectable via menu. Usually Yellow, Video, Red & White, Audio.
Mar 09, 2010 | Samsung TXK2554 25" TV
Can not get video to switch from Input Video one To monitor out on a TX DS787 Onkyo. (component Video) Have checked cables and also replaced cables with no solution.
Be aware that if for video 1 you are useing the yellow wire(composite in) you can only view that on the yellow mon out jack . component in can only be viewed on componet out. Same with HDMI.
Dec 29, 2009 | Audio Players & Recorders
No video or audio output. Normal TV not a HD one. Tried new Componet HD AV cable but still no joy.
Check the HD switch on the A/V cord. Make sure it's not set to HD or it won't work. Then try another TV. Then call MS.
Nov 14, 2009 | Microsoft Xbox 360 Console
Xbox only sits on tv blue screen
Try usings a componet cable or a standard AV cable if your using HDMI then go to your settings and change it to HDMI output
Feb 16, 2009 | Microsoft Xbox 360 Console
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
Dvd connection
Yes! You can pass the video signal through the receiver. This is most useful when you have more than one video device (e.g. DVD, cable box, VCR,...), and you can use the receiver to switch to the audio and video for the selected source at the same time.
On the back of your Onkyo HT-SR800 there is a section labeled "Component Video." It has three inputs and one output. So, attach your DVD by component cables to the "DVD In" and then attach component cables from the "OUT" receiver connection to the TV.
If your TV doesn't have a component connection, then this addresses your other question. You can't gain anything with this, because your TV doesn't support it. Connect the DVD to the TV according to the highest quality connection that they both support, in this order: composite, S-Video, component.
If you are using composite, but they both handle composite, than yes, you will get a better picture by going to component (or even S-Video). If both devices support progressive scan, this could be a substantial difference.
Your receiver accepts component, s-video and component video, but keep in mind, it may not do "video switching." So if you connect the DVD in via component, but go out to the TV over composite, then you may not get any video at all (but feel free to try). Try to avoid this, but you may be forced to try depending on the limitations of the various devices that you are hooking up.
Jan 16, 2008 | Onkyo HT-SR800 System
Onkyo TX-NR801 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
