Dvd drive removal
How do i remove dvd drive from a acer aspire 3630 laptop
  • 903 Answers
Http://www.insidemylaptop.com/replace-hard-drive-dvd-drive-acer-aspire-3610-laptop/
go here and look on the site for some goood tips and pictures
I hope this helps
Posted on Dec 24, 2008
Wireless Button (Acer Aspire 3630) Doesn't Work
Press Fn and the wireless key at the same time. That should toggle your wireless on and off.
Jul 10, 2012 | Acer Aspire One PC Notebook
How to reomve a faulty CD/DVD drive from the Acer Aspire 5510 to enable replacement.
Hello
With a number of software manufacturers using DVDs to distribute their software releases, having a Acer Aspire 5510 DVD-ROM Drive is not only convenient but is practically essential to keep up with software releases. Unfortunately, if your laptop doesn't have a DVD drive, installing one isn't quite as simple as it would be if you were installing the drive into a desktop computer. This doesn't mean that installing a laptop DVD drive is difficult, provided you purchase one that is compatible with your laptop. 1. Check to ensure compatibility between your laptop and the Acer Aspire 5510 CD-RW Drive you purchase. The best ways to do this are to purchase your DVD drive directly from your laptop manufacturer, look for compatibility information on the drive's packaging or ask a knowledgeable sales associate. If buying online, make sure to read all of the drive's profile to check for compatibility information. 2. Remove the Acer Aspire 5510 DVD-ROM CD-RW Combo Drive that your laptop currently has. Flip the laptop over, setting it on a sturdy surface with the side that the existing drive is on facing you. Depending on how the laptop is designed, you should find 1-to-3 screws holding the drive in place; these screws may be on the bottom of the laptop or on the side next to the drive. Unscrew the screws and set them aside for later use. 3. Flip the laptop back over. Carefully remove the old drive, pulling gently yet firmly if you encounter resistance/ This will be the drive unplugging from the laptop's drive interface, so a small amount of resistance is not unusual. Once the drive is free of the laptop, set it aside. 4. Slide the new Acer Aspire 5510 Combo Drive into the empty drive port. Make sure that you press it all the way in so that the drive will plug in to the drive interface. Once the drive is in completely, replace the screws to secure the drive. 5. Boot up your laptop. Your operating system will detect new hardware and will load temporary drivers for the DVD drive; insert the driver disc that came with the drive to install the manufacturer's drivers in order to get optimal use out of your new Acer Aspire 5510 DVD-ROM CD-RW Combo Drive.
Hope this helps, if so do rate the solution Good Luck
Jan 10, 2011 | Acer Computers & Internet
I have an Acer laptop, but my dvd rom drive does not appear in the My Computer folder and in that case I cannot use it to open Cd or Dvd. I need help to solve this problem. Thanks.
It's actually a manufacturing problem. The dvd metal case atually touches the the interior metal case of the laptop causing a shortcircuit. Solution: Remove The DVD drive from its place by removing the screw of the drive from the back of laptop and then pull the drive gently out from the laptop case. At the end of DVD case you can see the metalic extension, with a little hole. Cover that entire area with something, i used a sticker, but let that hole free, so you can put the screw back in once you put the DVD drive back in to the laptop case. That's it. If your DVD drive has no other defects, it should work
Oct 27, 2010 | Acer Aspire 5520-5908 Notebook
It wont detect a dvd on my acer aspire 5315 laptop
If your laptop won't detect DVD drive try and check connection first. Turn your laptop upside down and remove three maybe four screw (deepens on laptop) directly over a DVD drive and pull drive out. Blow some compressed air inside of laptop and check for anything abnormal on drive itself. Then put it back in and check if it works. If not it's either bad DVD drive or bad motherboard. Thanks and good luck.
Apr 17, 2010 | Acer Aspire 5315 Notebook
I need to open an Acer Aspire 3630 in safe mode to remove a virus what button/s do I press
Hi:
While your computer is booting up, from being turned off, start hitting either f6 or f8 as soon as your screen is displaying anything.
Nov 20, 2009 | Acer Computers & Internet
I need to replace the keyboard on an Acer Aspire 3680 series laptop
Hi there.
Remove the laptop battery and the AC power supply, open the lid as far back as you can take it.
Get a small flat headed screwdriver, now, you have to take off the keyboard bezel, this is the strip of plastic above the keyboard with the power button on it, the best way to remove it is to start by the on/off button by gently prying the bezel up from the lid hinge, once you have one side out gently pull it up using your fingers, it will unclip and lift away.
Next you have to remove 2 screws from the top of the keyboard, these should be visible to you, once the screws are out carefully lift the keyboard up, you will see a ribbon cable that is connected to the motherboard, gently pull the tab up on the connector that the ribbon cable sits in and it should release it and you can now remove the keyboard and replace it.
To re-assemble just follow my direction in reverse.
Please post back with the results and for any additional advice if needed.
Good luck and thanks for using FixYa!!
May 22, 2009 | Acer Computers & Internet
How to replace my faulty DVD drive
Hey,
In most acer laptops you can remove the dvd drive by removing one screw from the bottom of the laptop. that will free the dvd drive and you can pull it out.
Above pictures are from another 5000 series model.
Let me know if you need anythidng else.
Thanks,
Ekse
Feb 21, 2009 | Acer Aspire 5610-4648 Notebook
My acer aspire4520 laptop is unable to detect my removable cd/dvd drive
You will need to install chipset driver but it will be much better if you reinstall all driver for it.
Acer Aspire 4520 driver for windows xp can be downloaded here :
http://www.drivercabinet.com/driver-acer-aspire-4520-windows-xp/
Nov 01, 2008 | Acer Aspire 4520-5582 Notebook
Acer aspire 3630 no sound
Please check this manual and let me know if this is your machine and i can send you a link for the free download
http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/b3e34421dc8aed8a482570ff00436bdd?OpenDocument
Thanks Misterdj
Aug 18, 2008 | Computers & Internet
Parmiters for acer aspire 3680 laptop
Hi, heres a few for sale cheap, http://www.ebuyer.com/cat/CD---DVD-Drives/subcat/Slimline-Drives
all you need to do is remove the keyboard on the laptop, and remove screws, once you have it open you should see a screw holding in the old dvd drive, just unscrew it and take it out and refit the new one and seal it back up and thats you..
Have a nice christmas
John
Dec 03, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
282 people viewed this question
David Payne
David Payne
