Can Techwood DV925B connect to TV without SCART socket?
I am thinking of buying a Techwood DV925B to use with an old TV that does not have a SCART socket. Does this box have an RF modulator, so I can connect it by the aerial cable only?
Yes
Posted on Dec 24, 2008
Can't get sound when plug my Lg tv to my Yamaha amp model ax-396
What sockets are you using on the LG TV to connect to the amp?
Having viewed the back of that Yamaha amp, it has no digital inputs, for either coax or optical. Many modern TV's have no RCA audio out connectors. Though people think the component RCA type connectors are these. In fact connecting the amp to them will produce no sound at all.
If the TV has a scart socket you can get a scart to phono out lead and use the audio out from that, providing you are not using the scart socket for a video device. If you are you will need to also buy a scart switching box see image(s) below. These often have RCA audio out sockets on them so you wouldn't need the lead.
Both available on Amazon.
Alternatively you can consider upgrading your amp to one that has digital inputs. Thus getting Dolby Digital, if the TV has HD channels built in.
Apr 21, 2016 | Yamaha Audio Players & Recorders
Connect hdmi goodmans tv
Forgive on this one but I do not have a soundbar but wonder if it has any other connections like phono for input as to me hdmi would be a strange choice. Hdmi leads are mostly alike in they are fully wired and carry a wire which directs a device to listen to it when turned on, also some hdmi sockets (like the old scart) are blessed with options.
Some may be input only while others set for in and out so it may be worth swapping connections on your TV to see if this changes the habit, though for me I would look to see if this soundbar has other sockets to use like phono (same with your TV if it has phono or scart socket options). Your TV instructions may show their ideal connection setup, otherwise you will have to shutdown your other item to stop it commanding the TV to switch through its sound. This "problem" is an old one with people using scart leads then I used to cut pin 8 (its control wire handing the descision to a user) but this new lead combo I do not know.
Hope this helps.........
Aug 29, 2017 | Samsung LN32A330 32 in. LCD TV
Our new tv does not have a scart socket. This is necessary for a deaf person's loop. Whatnismthe solution
Your TV might have and AV In connection. If so, buy one AV to SCART connector socket from local electronic spare part shop. Thus you can convert the AV in to SCART.
Jan 03, 2013 | Televison & Video
Connect VCR without tuner to record from television
If it has a scart, you can get a scart lead to connect it to your TV. You would need to set the VCR to the Scart socket, IE: AV1 etc.. to record. You wouldn't be able to change channel on the TV, to watch another channel while recording though. If you had a set-top box, you could connect that up to the scart of the video then record, while you watched another channel on your TV.
Feb 06, 2010 | Televison & Video
HOW TO LINK A OLD TV TO DVD WITHOUT SCART
Use a VCR in between and use the vcr auxiliary input to connect to your dvd. Then out from the vcr with good old coax cable...
Sep 07, 2009 | Televison & Video
Unable to record to VCR from Alba LCD TV(LCDW16HDF0
Tried all combinations of scart connections and channel settings ,without result.Finally connected an external freeview box to VCR AV2,with through aerial feed to TV.Setting TV toEXT-1 and VCR to AV2 and with scart to phono adaptors connected box audio and video "out "with phono leads to audio video "in" using an adaptor into the TV scart socket.
Jun 17, 2009 | Hitachi Televison & Video
I have installed a Techwood DV925B Digital Terrestrial Receiver but when turning on the tv to the first channel (usually BBC1) the picture and sound is badly out of synch. This corrects itself by switching...
Have installed a brand new Gold Plated Scart Lead (original Scart was probably defective). Incidentally this is not a Projection TV but an attempt to prolong the life of an old-fashioned Cathode Ray Tube.
Oct 17, 2008 | Televison & Video
Can i connect a ps3 to a t v without a scart socket ?
keithwill197
I am not aware of any TVs that have a "scart socket", however you are most likely refering to the DVI connection. See the link below.
http://en.wikipedia.org/wiki/Digital_Visual_Interface
This a type of HD connection that is normally used with computer but because a lot of people like connecting their computer to HD TVs this has become a common connection.
To answer your questions no you do not need a new TV. Mainly you need a TV that has your RCA input for audio and video which will work fine. Note my TV that sets on my work bench is over 10 years old and it works fine. Granted it is a 13" TV so I do not do alot of game play on it as it is too small.
Let me know if you have any more problems and/or questions.
Issken
Oct 01, 2008 | Sony Playstation 3 (PS3) Console
How can i watch dvds on this old sanyo tv?
does your tv have a scart socket or is it pre scart, if it does, and you connect the dvd player via the scart then the tv should auromativally switch to av when the dvd player is switched on. failing that, if you have no scart, then the only way you can watch dvd is by connecting a flylead from dvd player to tv, (take out antenna and put it in that socket) and then start a search if you can, normally the buttons for this are behind a flap somewhere on the tv. if you have no scart or a way of tuning tv, then i dont think you can watch dvd through that tv
Sep 06, 2008 | Sanyo DS24205 24" TV
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Televison & Video Logo
173 people viewed this question
Top Televison & Video Experts
