Question about Wharfedale Diamond 8.4 Main / Stereo Speaker
Problem with Diamond 8.4
Hi all! I just got a second hand pair of wharfedales diamond 8.4 They were supposed to work perfect before I got them but today I set up the whole system and the surprise is that one of the speakers is not working. Well, actully it sounds, just the woofer, and really low and bad. I've tried plugin the bananas of the other speaker(directly the signal that the other speaker was getting) and... definitely the problem is with the speaker. Any ideas on this? Should I try opening the cap on back (where the bananas are plugged in) and sneak around? Besides, I'm testing the "healthy" speaker and now I've some doubts. Of the 3 "drivers", the mid-range driver is the only one going crazy. The woofer doesn't vibrate, I don't feel mucho movement going on with it. I've changed the setting to power up the bass and down the trebble, but the woofer still doesn't vibrate. Is this normal? Thanx! Javier
  • Javier Olaza Apr 13, 2007
    Thanks for the comments.
    I've checked the bridge on the back and it's in place. If I remove the bridges they I hear nothing at all.
    I've tried plugin the cables just to the LF and HF inputs (separately). In the good speaker both work.
    In the faulty speaker, HF doesn't work at all and LF works really bad and low, plus only the big driver works, bad, but works a little bit(woofer?). The mid-range driver doesn't make anything and in the other speaker the mid-range is the one that really makes everything and vibrates the whole time (the woofer in the good speaker doesn't really vibrate).
    I know it all sounds quite strange... but that's what I'm dealing with now.
    You think opening the back cover (where the connectors are) would help??
    The problem is that I bought them second hand vie eBay 3 months ago. I couldn't test them earlier because I didn't have the amp yet. I got it 2 days ago.
    So, that cross over issue, would it have an "easy" solution?
    You think I could try it myself?
    Thanks for your help!
  • 779 Answers
No - sounds like the speaker/ cross over is faulty - I assume there are only one set of connections on the back - on some speakers you have 4 connections for dual wiring - and you usually bridge those out Play a piece of music with some drumming in it and you should see the midrange move a lot Just to make sure there is not a problme with the Amp - swap the speakers around - so you have a left speaker and a right speaker connected physically move the left speaker over to the rightside and connect to right side cables - and the right speaker to the left side and connect to left cables Now if the problem goes over to the other side - its the speaker thats fault if it stays on the sam side - its the amp
Posted on Apr 13, 2007
  • 1 more comment
  • wayne walker
    wayne walker Apr 13, 2007
    just looked at the manual here http://www.wharfedale.co.uk/images/range...
    and they are bi-wired speakers - so make sure the bridge is in place
  • wayne walker
    sounds like a cross over issue maybe the caps have gone bad -
    can you take them back to the guy who sold them to you - before you start opening them all up ...
    otherwise you could try opening the box....
  • wayne walker
    wayne walker Apr 17, 2007
    it may be the crossover, the connections, or faulty blown up speaker drive units....
    you could call wharfedale and ask how much a replacement cross over would be....
    and replacement drive units - its not a make i have taken apart - but they are very simple to replace the parts - assuming the crossover does not have any settings (variable pots ) on it that need a wave machine and sound room to set up.
    I have replaced speaker drive units in monitor audio, Bose, tannoy, rogers, spendor all quite successful for people. Never replaced a cross over yet.... they are normally pretty stable electronic items
Safe to use 4 speaker with Technics Receiver?
The best thing to do is place a VOM meter to confirm that there are 6 ohm speakers
Nov 21, 2014 | Technics Audio Players & Recorders
I have a pair of Wharfedale Diamond III speakers that wer given to me. They worked for anout 1 year and now they don't work. Are they worth repairing?
BOTH died?? Together?
The subjective answer to that question is yours to arrive at. It would probably depend on whatever is wrong, availability of parts and overall cost to repair them.
Aug 25, 2011 | Audio Players & Recorders
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
Fossil fs-4167. the small fake diamond in it is stuck on sec hand
You have to open your watch, take out stem completely, then take out whole movement and release the stone. I you have steady hands, nimble fingers and a pair of tweezers, you will be able to refit the stone using Superglue.
Jan 12, 2010 | Fossil FS2920 Wrist Watch
User manual
try safemanuals.com or elitezoom.com
May 31, 2009 | Wharfedale Diamond 8.3 Main / Stereo...
Speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Jan 27, 2009 | Denon AVR-2105 Receiver
I have a pair of Wharfedale Diamond 7.2 Anniversary speakers and one of them has a blown woofer - how do I get into the speaker - there are no apparent screws to access into the cabinet? Help Also,...
On the back of the speaker are six deep holes that screws the back panel to front baffle.There are six sponge plugs normally.You have to dig these out with
a long standard screwdriver or however you can get them out to expose the 6 Phillips head screws below them.Remove the 6 Phillips head screws and the whole speaker comes apart,leaving just the box.Good luck.
Jan 27, 2009 | Wharfedale Diamond Anniversary Main /...
Pairing Pioneer BTB-200 with HTC Diamond
My HTC Touch Diamond paired with BTB-200 after I installed the JETware software. When pairing make sure that your bluetooth is on and visible, and that under services only the box for "hands-free" is checked.
Sep 27, 2008 | HTC Cell Phones
Wharfedale 8.3
Is it old ? Is it making a rattling noise inside ? Completely lost its sound as in completely stopped sounding like a woofer and has higher frequencys coming out of it or as in no sound at all coming out of it ? I would say it's probably the crossover, perhaps a burnt resistor.
Aug 05, 2008 | Wharfedale Diamond 8.3 Main / Stereo...
Wharfedale Diamond 8.4 Main / Stereo Speaker Logo
464 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Joaquim Martins
 Grubhead
Grubhead
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
