Question about Esker SmarTerm Essential VT
Smarterm smartmouse I use smarterm as my terminal emulator. In the past, on other machines, I have been able to configure smartmouse to have an array of functions associated with left/right click, doubleclick, etc. For some reason, on one machine, the only function displayed is left click, with a function of 'none' and even this I can't change - all the right click and doublclick functions are not there. Any idea why?
AT-8000GS/24 reset password with out reset button
Forgot or lost the password
Contact Allied Telesis Technical Support for assistance.
Apr 22, 2014 | Allied Telesyn ?AT-8000GS/24PoE 24-Port...
Why do i have to press enter after i scan
You need to configure your scan wedge or terminal emulator software (which usually includes wedge functionality) that processes scanned data to append a carriage return onto the end of what it is sending. Most software includes this as a configuration option, though sometimes you have to manually append a Carriage Return (ASCII code 13, Hex 0x0d, terminal emulation \r)
Jan 21, 2014 | Symbol MC70
Hi, I have intel SSR212MA and data on it. I reinstall DOM, How can i assign IP to SAN and restore data? Regards, Anees UR Rehman
Hi ,
Bro Attach a serial cable to the storage system and connect to a laptop. Open a terminal emulation program to run a text interface, such as HyperTerminal* or ProCommPlus*. Use the following settings to configure your session:
  • Bits per second = 19200
  • Data bits = 8
  • Parity = None
  • Stop bits = 1
  • Flow control = None
  • Backspace key sends = Del
  • Emulation = ANSI
If using HyperTerminal, set the properties for the backspace key and emulation after the session is established. If you exit the session and return to the session in order to use the Configuration Interface, the screen will not open correctly.
Feb 23, 2011 | Intel SSR212MA Hard Drive Array
Occasionally a user reports that characters being typed do not appear on screen. Smarterm v12.1 configured as Digital VT session. Reboot of workstation fixes problem. Is there some sequence of keys user...
If "echo" is running, the terminal echoes what is being sent to the server. However, if "backslash" mode is enabled ("echo -e"), then the command "\c" tells echo "produce no further output." Try "\c" to see if that will toggle the command. If not, try "\C" or "\e" (escape). "echo -E" turns off the backslash mode entirely.
Nov 14, 2017 | Esker SmarTerm Essential VT
I wan to reboot my wyse 3150se what program do i need ??
Do you want to reset the configuration of the terminal box? If so, you may try unplug the power cord or pressing in a little hole on the back labeled as Reset. If you want to close the session with the server, you can logoff there in your terminal program (telnet, remote desktop, terminal emulator or a dial up terminal) or citrix.
Sep 12, 2010 | WYSE Winterm 3150SE Network Terminal
I cannot access to its configuration page
connect the blue cisco cable to the console port of the router concerned. Then using a pc based terminal emulator such has hyperterminal or putty (download using a google search), login into the router. when in privileged exec mode, type the following command, show running-config, or wr term or sh run and you will get to view the configuration.
Dec 04, 2009 | Computers & Internet
PAssword Recovery for Allied Telesis 8000s
try
usename: manager
password: manager
also try
usename: manager
password: friend
Mar 12, 2009 | Allied Telesyn Computers & Internet
Cannot read symbologie/BarCode: i25(interleaved 2 of 5) from an MC9090-G running VT100 emulation. How do I configure the scanner within Telnet-CE/Wavelink?? Thanks. Dante Barboza
You will need to configure the telnet emulator from your pc first and download it to the terminal after.
Check the version of telnet emulator you have. To do this, go to the options menu on the emulator and click on about wavelink.
Register yourself on www.wavelink.com and download the same client version as installed on the terminal. (Don't forget to download the Active sync version.
Tweak all the configuration parameters on the emulator once you have installed it on your pc also enable i2of5 symbology and then download the config only to the terminal.
Jan 06, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Run Compaq Array Configuration Utility
Hi Foambob,
Try all means to get a smartstart CD.
Normally new version will be able to use on older hardware , but no guarantees.
I have always found it easier to use smartstart CD auto mode.
You can also do the install and then run ntssd to update all the drivers etc., but I don't recommend it for novices. Use the auto mode , it takes longer but safely and surely.
Good luck
May 21, 2008 | Compaq ProLiant 5500 Server
Configure for emule
You must open ports on your router to allow incoming traffic while using eMule. eMule uses three ports*: 4662 (TCP) 4672 (UDP) 4711 (TCP) Visit eMule here. * To prevent getting a low ID (Firewalled), open additional TCP ports between 4661 and 4665. Also, limit the number of connections in the eMule software. You may need to change the TCP Clientport to something other than 4662.
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
Computers & Internet Logo
54 people viewed this question
Top Esker Computers & Internet Experts
David Payne
David Payne
Are you an Esker Computer and Internet Expert? Answer questions, earn points and help others
