Question about Panasonic SC-BT100 Theater System
SC-BT 100 Error Code f61
When I switch my Panasonic SC-BT100 home theatre system on it immediately turns itself off and displays the error message f61. I only had this delivered yesterday! Please help
Had the same problem. Found that the code refers to the cooling fan. Could be that the fan is dusty or not running when the system starts up. I removed the fan with the two screws and reseated the plug. Make certain that the short, black wire (that seems to go to nothing) is securing the plug to the board.
Posted on Apr 14, 2009
Fan stalled at switch on due to dust build up on fan blades etc. dust out with compressed air.
mike.
Posted on Nov 06, 2011
I have a panasonic sc BT 100 blu ray home cinema system, the iPod and optical inputs appear to not to be working, are there any internal fuses that could have blown
Inputs are not fused. Have you looked at the manual(s)?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Panasonic-SC-BT100-Home-Theater-Systems-manual/id/17669ag210/t/2/
Digital inputs need to be assigned. The optical cable must be routed with no tight bends.
Jun 29, 2011 | Panasonic SC-BT100 Theater System
Turn on dvd panasonic sc-ht440 the display see me f61
Hi, F61 is and amp error code. probably needs an output ic. could be a shorted speaker or bad cooling fan. Disconnect all speakers and turn it on. if the fans run and it still displays f61 then odds are very good an amp ic is bad.'''Hope it helped.
Have a nice day..
Feb 24, 2011 | Panasonic SC-HT440 System
Home cinema panasonic sc-bt100 error code f61 what does it mean
I have same F61 issue, purchased a new fan fitted it today, and I have the same error code??
Dec 13, 2009 | Panasonic Audio Players & Recorders
My panasonic sa-vk90d is displaying an f61 error
That code means the audio amplifier IC are damaged and need to be replaced
Jul 13, 2009 | Audio Players & Recorders
F61 error code
Sorry to hear about your error code F61
This code refers to a High Limit Temp. condition.
This is most likely caused by the cooling fan.
If the Fan has stopped running or not running at full speed, you will recv. this error message and the temp. reaches high-end limit.
Please check the cooling fan, any possible air flow restrictions and correct running RPM.
Hope this information has helped you.
Readers, please rate your technicians information.
Thanks,
John Ray
john@johnrraycomputer.com
Jun 30, 2009 | Panasonic SC-HT740 System
DISPLAY STARTS OK THEN F61 APPEARS THEN STEREO SWITCHES OFF
Probaby needs the output ic. F61 is an output/power error code. But check that the fans turn before trying to replace or taking it in to be fixed. If a fan is not turning you will get F61 too.
Feb 21, 2009 | Panasonic SC-HT441 Theater System
Getting F61 in Display of Panasonic SC-HT700
I have gotten the f61 error code on my SC-HT700. No idea what the problem is.
Aug 30, 2008 | Panasonic SC-HT700 System
Error Message F61
Hi guys,
just had the f61 error code on my home theatre system, now i work with samsung dvds and tv's so the background knowledge is there ( i hope), i dont know if u guys noticed the fans making a noise whenever you switched it on before the fault happened but mine were making a hell of a noise, this prompted me to have a look inside and find 2 fans both of which were very dusty, just a 10 minute clean and a 10 min reassemble and im back up and running on all channels.
hope this helps guys
Aug 08, 2008 | Panasonic Home Theater System System
Panasonic SC-BT100 Theater System Logo
1,239 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
