Cable from wall does not work through box.
Channel search through box finds only 12 channels,but from wall tv finds 60.Box says ''unrated'',how do you switch over to ''cable'' input so it receives channels through box? Must be a set up button I can't find.Just took old tv out,box worked fine.Brand new 32'' Sony Bravia kl32l4000 will not accept box.
  • 68 Answers
What box? What is the wall jack connected to? There is not enough information in the description to provide an answer.
Posted on Jan 04, 2018
bangeepro
  • 4 Answers
SOURCE: No audio on pasma when cable set box set to certain channel
In that case two things might be happening. 1. HDMI/DVI cable you using might be faulty you want to change that or 2. The HDMI input of your TV set might be the problem. I will suggest you use component cable instead, I am talking about the 5-color-coded (green, blue, red and red/wihte) cable to connect the set top box to your TV.
Posted on Jun 28, 2008
SOURCE: Digivox DV3 cable box
press edit and go to bottom selection system instilation, press ok. type in 1004 on remote, nothing will appear till last digit entered. you will now see a hidden menu. there are three selections go to the bottom one and highlight, to the left another box says off use the right button and it will change to on. press exit till you come back. Go to sky movies or sport and a few minutes later you will see a box updating data, let it update and a picture will apear, all the pictures are now unscrambled. worked ok for me.
Posted on Aug 31, 2008
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
SOURCE: Can't set up my new Nikkai 5.8GHz video sender.
Could be that the Scart socket doesn't pass through the signals from the receiver. I had a Goodmans TV with Scart input which just didn't respond to the receiver. When I moved it to the Scart connector on my VCR it worked a treat.
Posted on Feb 03, 2009
19" Element HD Digital LED TV Model ELEFW195 Does not scan Digital Channels just Analog Channels.
Auto-channel search can't find digital channels - Community ...
community.insigniaproducts.com/...channel...can...digital-channels/.../13...
Aug 6, 2010 - When I ran the auto-channel search it could only find 4 analog ... Notgetting Digital Channels on NS-26L450A11 ... I've plugged the cable from the wall into the TV, and preformed the auto channel scan, with "cable" selected.
Troubleshooting Guide for Digital-to-Analog Converter Boxes
https://www.fcc.gov/.../troubleshoo...
Federal Communications CommissionIf you aren't receiving digital signals on your analog TV, you can purchase a ...antennas are designed only for reception of either VHF or UHF signals (but not both). ...The channel scan will automatically search for digital broadcast channels ...
Antennas and Digital Television ' Federal Communication
Jan 13, 2016 | Televison & Video
Lost channel 3 to watch tv on uverse
you need cable box on when you search so the tv can find it
Feb 16, 2015 | Westinghouse SK-32H640G 32" LCD HDTV
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
Wont find channels on auto channel search
Ensure that you have a good connection to your antenna/cable/satellite, and that you have selected the proper signal type in your TV menu.
If you are using a cable box or satellite, you might need to search for an analog signal on channel 3 or 4. If your cable/satellite box outputs an HDTV signal, then search the digital channels. If you are using an antenna, search for digital channels and set it the TV to Air in the Channel menu.
Apr 07, 2014 | AOC Televison & Video
Connected lg tv directly to cable wall jack. Can only get one channel. Manual scan grayed out. Ez scan does not find any channels. Main input is set to cable box. No option for just cable
Why not get a box and hook via rear inputs--not that expensive from most cable companies. If items such as the channel scan are grayed out it means something in the set is set wrong---
Apr 21, 2012 | Televison & Video
"Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Hi Someone gave me this old Sanyo TV Model # 31C4760, When I connect it with my cable it catches only basic (13 channels) instead of 60 channels. How should I see all the channels? What should I do?
If it is very old (with rotory/manual channel changer), you are out of luck unless you get a cable box from your cable company - this will let you set your TV on channel 3 or 4 and the cable box will find all stations for you. The cable box goes between your wall cable and your TV.
It your TV has an electronic tuner with a remote, try going into the setup menu and select signal source as CATV instead of antenna.
Please rate me.
Nov 20, 2009 | Televison & Video
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
Sharp vcr problem
The way to connect them is as follows:
1. Connect the cable from the wall to the cable input on the cable box.
2. Connect the cable box RF output to VCR RF input (VCR must be on channel 3).
3. Connect the RF output from the VCR to the RF input on your TV (TV must be on channel 3).
After all the connections are done, leave the VCR and TV on channel 3 and use the cable box to select the channel you want to record programs from.
Good Luck.
Jul 10, 2008 | Sharp VC-A410U VCR
Can't tune cable box to channel 2 to set up TVGOS
then you can try channel 3 or 4 if that does not work then you have to replace for a latest tv that does not use cable box.thes out of style
Mar 02, 2007 | Panasonic DMR-EH75 DVD Recorder/VCR/HDD...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
