Question about Toshiba Satellite Pro A30 Notebook
Problem solved ?
Hi Paul,
I've just red you suggest in article Toshiba A30 won't start. Is it correct? Does your solution fix the issue?
My problem is as follows:
I turn it on, power on led is lighting, hdd&fans spin up on full speed, but in 4-5 seconds it turns off and starts this again until I remove kind of power (battery or AC - it doesn't matter). The only thing why I am hoping, that sometimes it boots up properly and works fine until.... suddenly it comes (the BSOD) and freezes my A30, and it will not boot up again.
So I live in Hungary and need your help because of our local ASP don't cares about old notebooks mending, they are just expert in changing/replacing parts of computers. But if you tell me what to do, I can prepare to repair my old one.
thank you for your help
and regards
Arpad from Hungary
vegha@index.hu
  • Vegha Dec 26, 2008
    kopil:
    thank you. unfortunately Toshiba notebooks link doesn't have any useful information.
Won't charge. Red light come on for about 5mins then flashs red when i pull the trigger the red light comes on does not turn to green nothing works
Hi Peter,
I'm sorry to hear you're having difficulties with your DC16. From what you've described, it sounds as if the filter may not be correctly fitted - please follow the steps shown in our online support guide to resolve this:
http://www.dyson.co.uk/support/help.asp?article=1519&product=DC16-SY-STD
If you're still having issues after trying this, it's probably best if you get in touch with us directly, so one of our Helpline experts can run through some troubleshooting over the phone. You can call free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 01, 2011 | Dyson DC16 Root 6 Bagless Handheld...
My volume up on the Harmony 880 won't work. I've heard that one person did take it apart to clean the contacts, but that didn't solve the issue. Any suggestions? I don't even care if I...
If the buttons used to work then yeah it sounds like a hardware issue. You can go ahead and take the remote apart, but I don't think you will be able to fix it, unless you are good at soldering. Cleaning the contacts alone won't help. This same thing happened to the most used buttons on my Harmony One, and I just assigned the commands to the screen, so I could continue using the remote without those buttons.
If you want to try assigning the buttons to the screen, the steps in this article by Logitech will help:
http://logitech-en-amr.custhelp.com/app/answers/detail/a_id/9766/kw/buttons
I hope this helps.
Aug 14, 2011 | Logitech Harmony 880 LCD Remote Control
Don't know where problem exists in Toshiba A30.
These laptops had a lot of serious problems. Some of them were incredibly sensitive to static, and others did overheat, rendering the motherboard or CPU useless. I think there was even some kind of legal action against Toshiba on these models at one point, but I could be wrong.
You may not like this advice, but your $90 is probably better spent going towards a slightly used, refurbished or even new laptop that will outperform this computer anyway. You may only have to spend a couple of hundred dollars.
It sounds like you might know your way around the innards, so your hard drive can be removed and put in a USB hard drive enclosure so you can get to your old data from a new computer. These enclosures are very cheap.
I would not suggest continuing to try to resurrect this computer, as it will give you nothing but headaches going forward and will most likely never be reliable. You can remove your hard drive and sell the rest on eBay (or elsewhere) for parts.
Sorry if that's not great news, but that's my professional opinion of what you should do at this point.
Mar 20, 2009 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Pentax a30 problem
I also have the same problem with the A30. Anyone know how to fix?
Apr 23, 2008 | Pentax Optio S50 Digital Camera
Toshiba Satellite A30
click start,all programs,accessories,system tools,system information......check for conflicts..go into device manager and change resoures or if you dont need it disable it.you could delete it and itll reinstall when you restart and maybe find different resourses auto.if it is instaling generic driver goto hp drivers and download correct driver.
Feb 14, 2008 | Toshiba Satellite A1O A15 A20 A25 A30 A35...
Unlock to use Region 2 dvds
No region hack for this player.
Jan 29, 2008 | Toshiba HD-A30 HD-DVD Player
Red Screen
i have the Toshiba A1 and a benQ W9000 projector. I never had this problem with my Sony HS60. I switched the video from 1080i to 720p and then back to 1080i and it fixed it immediately .... its really annoying though
Dec 30, 2007 | Toshiba HD-A30 HD-DVD Player
Toshiba Satellite Pro A30 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
