Question about Euro-Pro F1063 Deep Fryer
Immersion Element (
I have a deep fat fryer and I lost the instructions it is a Euro Pro with Thermostat do I put the heating element in the oil? because it does not seem to work on the outside I can't put the cooking pot on it that way..HELP!!!!
  • Anonymous Dec 27, 2007
    Power is to the switch but will not come on,pushed reset buttonand the light or heating element does not come on
  • 944 Answers
This should be the info you need; http://www.euro-pro.com/europro/faqdetail.aspx?modelno=f1063 on the left is the link for the user manual. Hope this helps - please ask again if you are unsure :)
Posted on Apr 17, 2007
How to remove heating element
In order to remove the heating element of a Cuisinart deep fryer you need to do the following:
1. Unplug the fryer.
2. Tip the fryer and put the oil into a container.
3. Put the fryer on its side, with the open top over the sink and a bowl in the sink beneath it. Leave it this way so most of the rest of the oil can drain.
4. Wipe the inside of the fryer with a paper towel.
5. Put several layers of newspaper on the counter and stand the electric deep fryer upside down on top of the paper. You will see that there are rubber feet under the base held in by screws.
6. Remove the feet and screws and you will be able to take off the base to expose the electrical workings inside.
7. Locate the heating element which has wires leading to it. Start by removing the wires leading to it and then loosen up and remove the heating element itself.
May 24, 2015 | Cuisinart Kitchen Appliances - Others
How do i fix my savoureux fryer ?
Check your warranty info, it maybe a warranty repair.
Aug 18, 2014 | SAVOUREUX PRO LINE Dual Deep Fat Fryer
ELEMENT IN OUR F1063B WILL NOT HEAT ,TOLD BY LOCAL REPAIR THERMOSTAT CONTROL NEEDS TO BE REPLACED,IS THIS PART AVAILABLE AND IS IT POSSIBLE IT WOULD BE A WARRANTY ITEM,DEEP FRYER APPROX. 1 YR. OLD ...
Most items are 1 yr warranty, however Firm may fix this under GOODWILL if you state this item should be expected to last longer than 1 yr before breakdown...I found that in most cases if you speak to the company they will listen and be sympathetic to your problem.....Good luck.....
Feb 14, 2011 | Euro-Pro F1063 Deep Fryer
I need a filter for My deep fryer
I have the Euro Pro F1066 and love it. But, I called the Euro Pro people and found that there is NO replacement filter. If you go to their site and put in the model number, it shows only the following accessories can be ordered. This is from the Eoro Pro site:
Accessories
Oil Container & Lid
Replacement Fryer Basket
Replacement Control Panel with Element (1700 Watts - U.S. unit)
Power Cord
Replacement Basket Handle
Call 1-800-798-7395 to order
So, the only way to get a new filter is to purchase the Oil Container & Lid which would come with a new filter in the lid. I am trying to figuire a way to rework the original filter but have had no luck so far. I hope this helps answer your question ;-)
Jul 31, 2010 | Euro-Pro F1066 Deep Fryer
My deep fryer won't turn on or heat up.
Look for the safety switch that the heat element is supposed to push in when installed correctly. It may not be in all the way.
Jun 23, 2010 | Kitchen Appliances - Others
I burned up the heating element in my euro-pro fryer and am looking for parts . I didn't put enough oil in the fryer and turned it on before i finished putting oil in. It started smoking and the element(?)...
You can order parts by phone at Euro-Pro. Just click the link, eh? No parts are available online. This will take a bit of work to change the element. Make sure the seals are good.
Apr 21, 2010 | Euro-Pro F1066 Deep Fryer
My fryer just stopped working after frequent use, i tried replacing the cord but it is still not even responding, even to being reset via the reset button is there anything i can do, or is all hope lost...
it sounds as if the element may have burned out. here is a link to the model and manual and phone number of Euro-Pro. It would be worth your while to call them and ask their advise. Good luck
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=F2015L
Nov 27, 2009 | Euro-Pro F2015L Deep Fryer
Euro-Pro fryer doesn't return to temp after cold food drop.
If your timer is connected to the t'stat, you may have an expensive project on your hands. However, in the meantime, I would just get an egg timer or a digital countdown timer and use it since it seems to operate fine without the timer.
Feb 06, 2009 | Euro-Pro F1066 Deep Fryer
Euro-Pro 1066
Make sure that the slide rails on the control assembly are in the groves of the base unit when you assemble it. There is a safety switch inside.
Apr 18, 2008 | Euro-Pro F1066 Deep Fryer
Euro-Pro F1063 Deep Fryer Logo
344 people viewed this question
Top Euro-Pro Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Mai Lor
Tom Chichester
Are you an Euro-Pro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
