Question about Canon CLC 1180 Copier
I have a problem with my clc 1180 machine.. i have an error code E020 subcode 00A3... i changed the black sensor ,the developper assymbly, the dc controll board,drum..... still i have same error....can you help me pls. best regards.
  • 168 Answers
Ok so this is a code for the atr sensor.. you said you changed it is that the one right above the black dev that has the connector that plugs up under the control panel. if it wasnt take that one out and clean it... you can also check under serv mode copier display dens and see what iy says under window for each color they should be around 100 you may want to try to clear R-CON but then you need to put all adjs back to door specs
Posted on Dec 24, 2008
CLC 1180 with error E020 with sub 124
first check this site for the error codes.
clik here
The error code E020 refers to a density problem with one of the Drum Units.
ur hopper motor has jammed and it is not allowing the toner to go to the developer just open the hopper motor and put it into the developer or remove the connecter attacted to the developer. it will work . there is a gear actually on the motor which breaks.
So the only sol. is to replace, if it is under warranty caontact the customer care..
Goodluck,
Dont forget to rate me as fixya..
Jan 29, 2008 | Canon CLC 1150 Color Copier
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
E020 00a3
needs fuser assembly. probably bad thermistor.
Nov 14, 2012 | Canon CLC 1140 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Pls Solve my problem : Canon CLC 1180 Copier error Switch power Off and On again. E020 0481 Mr. Santosh Kolte. Pune.
The probable causes for error :
The developer has deteriorated.
• The developing cylinder fails to
rotate.
• The developing assembly is not
locked.
• The toner concentration (patch
detection) sensor is faulty.
• The developer inside the
developing assembly is faulty.
• The toner level sensor is faulty.
• The concentration sensor is
subjected to stray light (no cover,
front cover open).
• The photosensitive drum has
deteriorated.
In error code E020-0481, means that the problem is in black developer. So I would first try to replace Bk developer, check the developer station for malfunctions ( broken gears, broken developing roller bushings,... ).
Hope that helps!
Jun 20, 2011 | Canon CLC 1180 Copier
Error message E020 0400...any suggestions?
clean the blck sensor and in *4* instal,initialize k,swish of swich on the machin.
mohan
Apr 15, 2010 | Canon CLC 1180 Copier
E020-00A3
your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
Dec 24, 2008 | Canon CLC 1180 Copier
CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Canon CLC 1180 Copier Logo
220 people viewed this question
old marine
old marine
