Question about IBM ThinkPad R32 2658 Notebook
Toshiba A200 1Ai memory slot not working
I bought two 2gb ram,fitted them but only one showed up.I took one out and it would not start so i put it in the other slot and the laptop started so now i know which slot is faulty.
I tried pressing down on the slots and turned the laptop on but it was still the same.
Is there anyway i can repair this or do i need a new motherboard,if so where would i get one?
  • 3 Answers
New board, the actual ram slot is toast, you can get a replacement board from Toshiba themselves but at a retarded price, at this point cheapest thing to do would be to just put in one 2 gig stick in the working slot so at least you have 2 gigs and forget about the other one (replacement mother-board for your machine is roughly 200 bucks) i checked it at work (future-shop)
Posted on Dec 24, 2008
I put a 2gb ddr2-667 memory chip in the single (only) memory slot in my gateway nx100x notebook pc. The pc will not boot up with the 2gb memory card. Is there a compatibility problem or do I have a ba
yes, there may be compatibility problem. your 2GB ram may be dead. try your 2gb ram on other notebooks. if it is working on other notebooks, then your ram is ok. your notebook will support maximum 2GB ddr2 memory per slot. your notebook may not be booting due to unsupported frequency of your ram. maximum supported frequency for your notebook may me 400Mhz, and you are putting a 667MHz ram into it. try to put a 400MHz 2GB ddr2 ram in your notebook.
Apr 10, 2013 | Gateway Computers & Internet
How to replace RAM in Satellite M45-S165
http://www.irisvista.com/tech/laptops/ToshibaM45/Satellite_M45_disassembly_1.htm
You can click on any photo to enlarge it.
Step 3 photo shows the Memory Compartment.
Two ram memory (SO-DIMM) can be used. There are two ram memory slots.
1GB however, IS the largest amount for EACH slot.
Regards,
joecoolvette
Apr 14, 2012 | Toshiba Satellite M45-S165 Notebook
2G memory card not working
If the original memory card (RAM Stick) is working, then it just means two things; either the 2GB memory card is defective or incompatible with your system. Incompatible means the type is not for your motherboard or the 2GB is more than what your computer can handle. You dont need any drivers for your memory card (RAM).
Try to install a 1GB first and check if it is working. make sure the type (ddr,ddr2,ddr3) is the same as the original and the Bus speed (3200,667,800,etc.) is the same as well to eliminate incompatibility errors.
Hope this helps.
Jul 15, 2010 | Toshiba Satellite L305D-S5874 Laptop
I have a lap top Dell Precision M20 and replaced the old ram from the slot below the keyboard with 512 MB by a new with 1GB. It worked fine! Since I bought two times 1GB, I inserted also the second in the...
these different ram slots have different bus speed so they really don't work if you are using them both at once.
Please check your laptop's documentation about the speeds of these ram slots.
Dec 27, 2009 | Dell Precision M20 Notebook
I want to change the 2 x 512DDR ram by 2x 2GB DDR ram memories in my A205-S4577/Toshiba. Will it work?
hi,
it will work as your notebook is supporting maximum 4 gb RAM but please check that you are using 32 bit operating system or 64 bit one.
If it is 32 bit then the system will be showing 3.2 gb RAM only as this is the 32 bit os limitation.
Jun 03, 2009 | Toshiba Satellite A205-S4587 Notebook
Laptop screen dont like keyboard slot ram
The NX6310 laptop supports up to 4 Gb of RAM either 533 or 667 MHz DDR SDRAM.
When memory upgrades don't work, the problem could be incapable memory between RAM modules.
Try to use RAM from the same manufacturer, especially the manufacturer of the working RAM.
Use RAM that have the same speed specification.
Jan 21, 2009 | HP Compaq nx6310 Notebook
I put two 2GB RAM in my memory slot and only one is registering, so instead of 4GB RAM, I have 2GB. Why is this and what can I do to get the full 4GB?
ok i checked on your model and it says 2gb RAM max and so it is probably seeing both chips but only seeing 1gb each since that is what the slot is made for..
But to be totally sure you might wqant to check the bios and see what it says since some bios will sometimes give more details as to how many chips are installed.
or take out one chip and turn the computer back on and see if it shows 1gb or 2gb if it shows 1gb with one 2gb chip then you will know that the slot wont read more than 1gb.
Dec 04, 2008 | Toshiba Satellite A100-S8111TD Notebook
Hello My ASUS K8V-MX Motherboard has only two memory slot
Look into you're manual, go to pages 1-11 & 1-12.
The memory listed here has been tested by Asus to work correctly in the K8V-MX motherboard. In order for you to reach 2GB memory you will need DS memory. Double sided. This means there is 512MG on each side of a single DIMM, hence 2x1x 512MB DIMM equals 1GB. So you will need 4x 512MB to raxhl a total memory of 2GB. Please stay within the recommended memory listed on the Qualified Vendor List (QVL).
Simptronics memory it not on the QVL list. From time to time some memory not one the list may still function. This is not one of those times.
Mike
May 19, 2008 | ASUS K8V-MX Motherboard
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
IBM ThinkPad R32 2658 Notebook Logo
230 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
