Question about Sharp AL-1641CS Laser Digital Copier
Sharp AR-287 error code HR-00
I'm getting error code HR-00 on our Sharp AR-287 copier, any simple solutions?
    Problem Solver:
  • 12 Answers
The AR 287 does not have any codes that begin with "HR". Please recheck the display and post again with correct code and I will try and help you.
Posted on Jan 07, 2009
SOURCE:
MY SHARP AR-M207 DISPLAY ERROR CODE L4-00 KINDLY GIVE ME A SOLUTION
Hi Alafin,
An error code of L4 suggests a motor error. It could be something as simple as a loose cable but it could be a bad motor. I would suggest you call on a local dealer to repair this as you will probably need new parts.
Jun 14, 2016 | Sharp Used AR-M207 Copier Printer Scanner
Sharp ar 287 code h3-00
H3-00: Heat roller high temperature detection
Check and remedy:-
Check heater lamp operation with
SIM5-2.
If lamp blinks properly:
Check thermistor and its harness.
Check thermistor input circuit of
control PWB.
If lamp lights and stays lit:
Check lamp control circuits of AC
PWB and control PWB.
Clear the trouble with SIM14.
Jan 06, 2011 | Sharp AR-M237 Copier
SHARP AR-287
Is the code a H5 ? Is it a AR-163 or a AR-287? Is the copier making a load noise when making a copy? Basicly, the code means you are have more then 5 paper jams in the fuser & there is a problem there & the copier is locked up.... It's self saving it self
May 05, 2010 | Sharp AR 163 Copier
I have sharp ar-287 error ha-04. How to fix?
this sounds like you have a jam in your fuser unit.To remove this jam open the door at the left hand side,you should see a green lever to the back end lift up and take paper out,after doing this you then have to reset this error code.To enter service mode press P interupt C interupt key in 14 press start key then press CA.Photocopier should reboot if this does work then you need to get your service engineer out
Sep 15, 2009 | Sharp AR-507 Copier
I have a sharp ar-287 error l3 - 00 how to fix?
Hello sir; Try to make a copy without the cover then you may see the mirrow not moving out, you open the glass to serch the factor it cause this problem.
Jun 04, 2009 | Sharp AR-507 Copier
Sharp AR-287 HR-00 error code
I'm sorry for not getting back to you sooner - I lost track of this question. If you still need this info here it is :
H3-00 indicates a temperature problem in the fuser unit. not reaching a certain temperature within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Mar 30, 2009 | Sharp AR 163 Copier
F9-00 (Print Function) Error Code on Sharp AR-287
this copier will display f9-00 if the nework is not connected or the card is bad this means network connection lost usaally resting copier will work if the network is on if not call service
Mar 03, 2009 | Sharp AR-235 Copier
My Sharp AR-287 Copier is showing F2 error
there Should be 2 additional numbers. F2-??
Oct 29, 2008 | Sharp AR-235 Copier
I want a solution for a Sharp AR - 287 Digital Image problem
H4 for an error code on all Sharps indicates that the fusing temperature isn't correct. It needs to have a new thermistor installed or the heating lamps need to be replaced.
Oct 21, 2008 | Sharp AR-235 Copier
Sharp AL-1641CS Laser Digital Copier Logo
224 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
