Question about Dell W2600 26 in. LCD Television
Blue light is yellow no picture
Dell 2600 26 in. lcd
    Problem Solver:
  • 7 Answers
This usualy indicates that the monitor is not connected to the PC, make sure the signal leed is in properly, if it is try another monitor or another PC
Posted on Dec 24, 2008
TV picture goese black and white
Check your cables on the back of the TV and cable box. You either have it connected wrong, or they are loose. If you are using red green and blue, make sure that you are tightly in the red green and blue connectors. If you are using yellow white and red, then make sure you don't have the yellow in the green spot.
Mar 20, 2013 | Dell W3706MC 37 in. LCD HDTV
When i push the power on button it won"t turn on . the blue power light flashes yellow three times
Google Dell W2600 blink codes. You're tv is doing a self diagnostic and letting you know what's wrong with by flashing the yellow light. Count how many time and if there is a sequence to it, then look it up.
Feb 06, 2011 | Dell W2600 26 in. LCD Television
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
The picture is blue and yellow reds.
reset the settings to factory default. if that doesn't help, the colorwheel needs replacing.
Oct 21, 2009 | Dell 4100MP Multimedia Projector
Dell computer won't come on...only get yellow light, no blue
If the Tower has a blue light, then it appears to be working, I'd check the cable connection to the video port on the tower and the INPUT Select Button of the Monitor (I've seen people change the input select to DVI when connected analog for example)
Sep 14, 2009 | Dell E176FP 17" LCD Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
I have a dell w2606c lcd tv no picture or sound when turned on what can be wrong
when u turn the unit on, if u get a flashing yellow light, its your mainboard. otherwise, its your powerboard, its burnt out. must replace.
Jan 05, 2009 | Dell W2606C 26 in. HD-Ready LCD Television
Zenith 44" LCD TV
The yellow spot is due to the BLUE LCD and/or lens assy cracked, reason, to much HEAT! The blue is the darkest color and hold the most heat, so it goes first, always! In some cases it’s only the lens, however most of the time LCD is damage to. Parts are available, however install and alignment is timely. Quick fix is the complete light engine, which for model# E44W46LCD is part# 3141VSN916C, which customer cost is $1,449.27, wholesale for about $1,065.21. Rebuilt, if you can find it around 850.00 to 950.00. However the rebuilt does not always look as good as factory. My advice, TRASH set. This part will fail again in about 3 to 4 years, unless you watch a lot of white video. Remember, on a black or dark picture, all three LCD are blocking 100% of the light, causing extreme heat within the light engine. It’s a bad design.
TV Tech
Jul 13, 2008 | Zenith E44W46LCD 44" Rear Projection...
Dell W2600 26 in. LCD Television Logo
57 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
