The door won't lock on closing and the two hooks on the side of the door 'flop'
Apparently they are supposed to stay up, but just 'flop'
The spring
is off inside.
Normally the problem is
not the spring itself, but a broken
spring mounting tab on the door latch head (hook) assembly or the inner
door panel.
If it's the door panel,
it's usually easier and cheaper to use epoxy and some kind of hardware
to fashion a new spring mount.
The door latch head
(hook) is easy to replace or repair if that's the issue.
Normally
you have to separate the door panels as shown in the attached photo to get to the innards.
Or you can watch a YouTube video (not a video I made) here that
demonstrates how it's done.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
If the microwave door won't open the button might be broken internally. The button can be replaced.
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
The door latch broke off. We tried to regluse it but it will won't latch good enough for the microwave to cook. Will this be a costly item to fix? Are we better off buying a new Microwave?
