Question about Thermador P364GLCS Kitchen Range
Thermador P364GLCS oven wont work
The grill go wet after a spill. I cant figure out what the error code is. the blue oven light blinks 4 and the the pre heat light blinks three. I cant figure out what it means
Thanks for your help
4 Suggested Answers
SOURCE: Flashing Lights on Thermador Oven/Range
I HAVE THE SAME PROBLEM. MY OVEN BINKS ONCE FROM BAKE AND TWICE FROM THE OTHER LIGHT. OVEN DOES NOT WORK, ADND WE REPLACE THE CONTROL BOARD ALREADY. WHAT DOES THAT MEAN?
Posted on Jan 31, 2009
the lights flashing in a sequence indicates the error code. The error codes indicates what the problem is with your stove. Based on the response to your message, it sounds like their error code is 12, one then two. It is not clear what your error code is.
There is an explanation of the error codes on the wiring diagram that comes with the stove. I found the wiring diagram for my stove taped to the inside of the kick plate. The kick plate had to be removed to find it.
my oven is not working either. the error code I get is 34. I am told by a technician that error code indicates that the computer is not recognizing that the cooling fan is operating, which is why my oven will not work.
When I try and order a new cooling fan from Thermador, the website says that it is temporarily out of stock. Obviously, other people are having the same problem I am.
Posted on Mar 06, 2009
SOURCE: Thermador Pro Harmony Range--> Blue Lights Blinking
thermador rang, blue light blinking. Oven is not working,
Posted on Feb 05, 2010
Flashing lights error code?
count the blinks, pauses and blinks again. it may be a single digit code or a two digit code.
Feb 19, 2014 | Thermador Ovens
I have a Thermador model smw272 and F 7 is flashing on the lower oven display, with a beeping sound every second.
Hello & Welcome to FixYa
F7 error code is displayed when the clock assembly/electronic range control (ERC) goes bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 30, 2011 | Thermador SMW272 Electric Double Oven
Thermador P304CS error code 4 preheat blinks then 3 heat blinks
I wanted to post this up in case someone has trouble finding an answer and what worked for me. I found somewhere else that the 43 code (4 preheat;3heat) blinks was specific to the cooling fan or the temp sensor. I had started to remove the temp sensor off the back wall of the oven but was unsure where the wire ran to. There is a specific Ohm value it should have around 1080 I think (not 100% postive).
What I found during that search is what solved the oven problem for me. On the top of the range, if you pull off the grill grates and remove the center stainless cover you can access under the burners. You can do this without removing any wires or hardware. In the back of this area is a small cover held in by 4 screws. Remove that. Underneath it is the cooling fan switch. It is a mechanical switch that when the fan kicks on it pushes a metal sail that then causes a connection in the switch letting it know the fan is operating. This switch had a little bit of corrosion on one terminal but it is also prone to getting dirty. Clean it off and try to restart the oven. The sail should move forward and the switch makes connection. For me once it was cleaned and any corrosion cleaned off, my oven worked just fine. This is a pretty easy check with the 43 code since it does not involve a lot of invasive work. Hope this helps someone.
Mar 07, 2010 | Thermador Kitchen Ranges
Oct 03, 2009 | Thermador Pro Harmony PRG304EH (Gas)...
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Jan 31, 2009 | Thermador PGR366 Gas Kitchen Range
Blue blinking lights
I'm Neil
No problem
Check your Manuel
Call The Manufacturer you have a warranty!
Please rate my solution!
Jul 22, 2008 | Thermador PGR366 Gas Kitchen Range
Thermador PDR30 4ZS/05 duel fuel
It's the motherboard. You must have had a power surge. I just replaced mine. Motherboard + shipping 200.00. its not easy to replace but not so difficult.
Mar 11, 2007 | Thermador PDR304ZS Dual Fuel (Electric and...
Thermador P364GLCS Kitchen Range Logo
91 people viewed this question
Top Thermador Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Steve Allison
Steve Allison
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
