Question about Panasonic AJ-D400 Camcorder
Panasonic aj-d400 turns on but does not do anything after that
Hi I have a problem with my aj-d400. I can turn on the camera with the switch but nothing seems to work.. the lens part works perfectly. I cannot even switch off the camera with the on/off switch.. nor the recorder nor the camera reacts on anything with the switches. To switch off I need to remove the battery. the menu does not work either, even if i change the settings by pressing buttons it would not show any change on the display. can anyone help me out on this problem??? thanking you all in advance for your precious time. azam
  • 71 Answers
مرحبا عزام انت عايش وين وبتعرف عربي لنتفاهم hi do you know arabic as i see from your name you are arabian?? i may help by that camcorder regards
Posted on May 03, 2007
SOURCE:
Camera says turn off and turn on panasonic lumix dmc-fs5
While you are turning the camera on, hold the lever which you use for zooming in. The lens should extend before you get the annoying message about turning the the camera off and on. Then, gently apply pressure to the lens as if you wanted to push it back to the camera. While you are doing this, turn the camera off (lens should come back into the body of the camera). This will solve your problem.
Thank you!
May 17, 2010 | Panasonic Lumix DMC-FS3 Digital Camera
My Dell Latitude D400 laptop's USB ports stopped working. They used to work fine, now they don't recognize anything (card readers, mouse, camera, etc.) I removed the USB port drivers and reinstalled. It...
USB port is corrupt...if all that you said is what is happening then the best is to
buy a keyboard to USB port convertor....
refer this image....Ebay has it for about 1$
May 10, 2010 | Dell Latitude D400 Notebook
Do you repair camera Panasonic P2,no output in LCD
We do repair the models above. We order parts from Panasonic.
Mar 08, 2010 | Panasonic AJ-P2COO8HG for AG-HVX200...
Turn the camera off and on - can't do anything!
I have the same problem. I contacted Panasonic and they will attempt a repair. I really have no other alternative than junking the camera.
Aug 03, 2009 | Panasonic Lumix DMC-FX100 Digital Camera
Aj-d200 video camera, cassette door stuck partially open. best diagnosis and/or remedy?
Partially open sounds like a mechanical problem with the cassette housing/door assembly. The door usually stays fully open or will not open at all, caused by component failure on the mechanical driver board. Check to make sure nothing is stuck in the mechanism, like a label or a broken piece from a cassette. If the door will move, but will not latch closed, the problem is most likely on th emechanical driver board.
Mar 25, 2009 | Panasonic AJ-D200 Camcorder
AJ-D250 PANASONIC E-62 PROBLEM
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Frozen Camera
Try letting it drop about 4 tto 6 inches on a hard service covered by a paper towel. Don't let it land on lens of course. You can remove the mem card. It has 13Meg of internal.
Mar 22, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic AJ-D400 Camcorder Logo
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
