Question about Samsung PCL541R 54" Rear Projection Television
Samsung pcl5414r 54 in rear projection. red all over screen
I have red wavy lines on the screen and everything on the screen has a red blur beside it. I could not get it to converge as the cross hairs were way off. I also have a electronics smell as if something is getting HOT. I removed the back and found that one of the IC's (STK392-040) was very hot. I replaced both IC's and still have the same problem. now I cannot begin to converge the red. it does not move. I replaced the IC's as i seen another problem similiar on the site and that was the solution. I am not sure where to go now. I do not know what is getting hot and making the smell. I would love to fix this t.v. it is only 6 yrs young and I have it recessed in a wall. the recess hole was made to fit the t.v.
thank you
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, were the power resistors on the same board as well as pico fuses checked/replaced? If not, the it is highly possible that the STKs were again damaged, would have to be replaced together with the said resistors and pico fuses.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 24, 2008
  • Louie  Role
    Louie Role Dec 27, 2008
    Hi again and welcome back to FixYa,
    Appreciate the direct "Ask Me'.
    Based on your original post,
    only the STK ICs were replaced. Presumably 392-040, the surrounding
    resistors and pico fuses could very well have been affected as well.
    Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
    RZ104 -RZ106 - 270 Ohm 1/2watt
    RZ133-RZ135 - 27K Ohm 1/16 watt
    RZ136 & RZ138 - 3.3K Ohm 1/8 watt
    RZ146 and RZ147 - 3.9 Ohm 2 watt
    RZ148 and RZ149 - 150 Ohm 2 watt
    while the pico fuses would look like the image below.
    Cheers.
  • Louie  Role
    Louie Role Dec 31, 2008
    Any updates or developments?
  • Samsung Master
  • 19,396 Answers
The problem sounds like a burnt convergence IC (STK), have the ICs on convergence board teste and replaced.
  • Ginko
    Ginko Dec 24, 2008
    If you get wavy distorted lines, usually it is a convergence proplem. On the first case it was the convergence IC indeed, infact the problem was an STK392-040, that is a convergence IC.
    Replacing a convergence IC it is not a job for beginner, as you need to use thermal compound, and to do a precision soldering job inside the tv, after you test the pico fuses at the base of the IC to find out if the ICs had blown.
    An easier job is replacing the convergence board (always after testing the board, the problem may be elsewhere.
    Replacing the C board is easier than replacing the ICs, but more expensive, and must still be done by a technician.
    After replacing the faulty part , a convergence setup procedure must be done. You find the procedure on the service manual.
    You can call the phone number here to look for parts and service manual.
Picture show blurred and 3 lines across the screen color of red, blue and green
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hello, I've got red wavy lines across screen
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 22, 2009 | Samsung HCM5525W 55" Rear Projection...
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Double red & green lines on screen
thats a connector issue in your LCD, it might be your LCD connector have lose connections check it.
Jul 10, 2009 | Samsung PCN5425R 54" Rear Projection...
Red and green wavy lines
If the distortion that you see can be described as somewhat of a 3-D picture, the problem is teh convergence circuit and this can be fixed easily. Also, if you can solder, you can fix this yourself. If you wish to do this, please update this and I'll provide you with some instructions.
Dan
Sep 12, 2008 | Akai PT5492S 54" Rear Projection...
Hitachi 57UWX20B 57 in.
*Screen Looks 3-D
*Colors wont align
Sep 08, 2008 | Hitachi 57UWX20B 57" Rear Projection...
SAMSUNG REAR PROJECTION TV PICTURE WAVY LINES, DUPLICATE IMAGES RED AND GREEN TOP OF SCREEN
This is a convergence problem. Please post the model number so I can give you details.
Thanks,
Dan
May 28, 2008 | Samsung Televison & Video
Pitcture is Wavy
Sounds like the tuner is going.
Dec 05, 2007 | Akai PT4799HD Rear Projection Television
Red shadow
it sounds like you are having convergence problems if that is the case the ic's will have to be replaced
Oct 17, 2007 | Akai PT5492S 54" Rear Projection...
Samsung PCL541R 54" Rear Projection Television Logo
131 people viewed this question
Jerry Greenberg
Jerry Greenberg
