Ruud UBHC Air Conditioner
Problem for Ruud UBHC Air Conditioner
Pilot light not coming on
By zoranstojkov on Dec 24, 2008
I have ruud 90 plus achiever furnace about 11 years 0ld. the other day I noticed that the my house was getting cold and the furnace wasn't coming on. When I tried to reset it as per the instructions it didn't work until I turned the power and gas off and tuned back on 6 hours later in the morning that it worked. It worked for 18 hours and now same problem same solution again. How can I fix this problem?
Clarification Request
Posted by RDrennan on Jan 05, 2009
If the unit operates for a short times then locks out and is reset by cycling the power it is going into a "Hard Lockout" and this can be caused by several things. The most common are pressure switch and flame retification issues. Both of these issues will display erro code flashes.
Here are the codes for RUUD Furnaces:
Furnace: 1 blink. Soft lock out. Ignition sequence failed to prove flame. Check polarity & ground.
Flame sensor should be clean and surrounded by flame. Burner mounting screws must be
tight.
2 blinks. Pressure switch did not close when inducer motor started. Check for blocked
flue or obstructions in pressure switch tube.
3 blinks. Open limit switch. Check for dirty filters, closed registers, crushed ducts.
Temperature rise must match range stated on unit tag. Increase fan speed.
4 blinks. Pressure switch did not open when inducer motor stopped. Replace pressure
Switch.
5 blinks. Twinning circuit problem. Control board cannot confirm communication second furnace. Check twinning dip switch setting
Once you have a code, please feel free to contact me and I can walk you thru a more indepth diagnostic of the unit to repair the issue or direct you of what you need to do...
Richard (Rick) Drennan
Global HVAC Distributors
RUUD Field Support Representative / Instructor
rdrennan@globalhvac.com
900 Spreckels Ave
Manteca, Ca. 95336
Office (877)448-7263
Posted by dwkcool on Dec 25, 2008
you need to see what code is flashing on the control board and look on the door panel to see the flash codes
Same Problem
Jan 22, 2009
-   I have a RUUD UGHD-125A-ER gas furnace. I have no heat and the home owners told me to check the pilot light and relight if needed. After removing the front cover and seaching for what I can only guess might be the place a pilot light would burn, I find myself at a loss. I've always had electric heat.
What am I looking for and where might the pilot light be?
Thank you for any help you can offer
Kathi -   Guest
Solution #1
posted on Nov 11, 2009
Not Rated)
ac_jc0103
Rank: Apprentice
Rating: 0%, 0 votes
tengo mi ruud furnace pero prende el piloto despues laflama y esta asi como por 30 sec despues se apaga q puede ser el problema
Was this helpful?
Yes
No
Solution #2
posted on Jul 27, 2009
Not Rated)
jeremy2142
Rank: Master
Rating: 100%, 1 votes
Look in the small peep hole on the cover when the furnace will not come on look in and try to count the number of slow and fast flashes and you will have a code ON THE panel somewhere there will be a key with all the possible codes this will help you determine whats wrong.
Sounds like a pressure switch or high limit
Was this helpful?
Yes
No
Solution #3
posted on May 02, 2009
Not Rated)
jvangel1
Rank: Wiz
Rating: 82%, 57 votes
sounds like the unit goes in lockout mode which shutting off the power and putting it back on will reset the computer now the next time it happens dont shut off the power and in the blower compartment on the board there will be a blinking light count how many times and on the door it will explain do not remove the door until you have counted the beeps throgh the little hole
Was this helpful?
Yes
No
Popular Solutions for Ruud UBHC Air Conditioner
Questions and Unsolved Problems for Ruud UBHC Air Conditioner
Do you recommend Ruud UBHC Air Conditioner?
Answer
Answer
I am installing a used heat pump into my exsisting gas furnace. All have left to do before charging... (More)
Answer
I have a similar problem. It gets up to 78 degrees in the house and the ac unit is set to 65. It... (More)
Answer
Hello.. slight problem. Rudd silouette II a/c gas furnace. Fan runs on low speed, and will not shut... (More)
Answer
I have messg error 6 waht mining my air condtion Ruud
Answer
I have a ruud ac unit running heat for the second time this winter and now not heating. blowing cool... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ruud UBHC Air Conditioner:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
