Which One To Choose?
Dear Sir,
I am Fahad from Pakistan, I am going to build a Computer with the following things but I will upgrade it with a Graphics Card after wards:
1.INTEL CORE 2 QUAD Q6600 2.40Ghz (8MB CACHE - 1066 MHZ FSB)
2. Asus P5QL-CM with 256mb VGA built-in
3. 160gb Hard Disk
4. 2gb Corsair Dominator Ram
5. DVD-RW
6. Standard Casing
These all things are in my budget. The things I am confused in are. First, the processor, I want to ask that is this processor good or should I upgrade it for future benefits. Secondly, is this motherboard be suitable for future, like I add a XFX Graphics Card to it.
Thanks
Fahad
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    I didn't see any detail at Asus on what Bios is shipping currently. Intel and Asus state the Bios needs to be 0211 or greater or you will have to flash it for this CPU to boot.
    That CPU is Wattage hungry so your power supply should be at least 550Watts capable of a sustained demand of 450Watts minimum.
    The motherboard you selected is really small, I wouldn't put this in a small system case and it and your future video card will be heat generators and you will want a front 120mm and rear 120mm fans minimum. The larger the case width the better as you have more air inside, not to mention your hands at work.
    Any Antec Sonata level case will do. A side door with air funnel is advisable for the CPU fan.
    This board is also not able to provide dual PCIe SLI. Which isn't really needed much anymore.
    Since your board can have 6 SATA devices that's suitable for dual DVDs on SATA and four SATA Hard Drives. That's more heat and the need for a case that will support four hard drives with proper cooling, ideally the front 120mm fans should be in front of or just behind the hard drive cage.
    For the money, the motherboard could be better. But, you seem be building an Intel centric system, so it will do. I found its better to have full size AT boards frankly as the components aren't squeezed into a small amount of space.
    What is the make and model of power supply you will be using? What are you actual cooling objectives?
    Novelist:
  • 171 Answers
What are you going to use the computer for? Gaming? Or Office use?
The processor is on the high-end. It's actually overkill for normal word processing / internet surfing. It's pretty good if the computer is for gaming.
Your motherboard is okay, but not great. Perfect for office use, but I wouldn't recommend it for gaming. It will not be very upgradable. It lacks RAID, and SLI/Crossfire support, and it only has two slots for ram, not four, making upgrading your RAM expensive.
My suggestion for a motherboard is the Asus P5N-D:
http://www.asus.com/products.aspx?l1=3&l2=11&l3=627&l4=0&model=2033&modelmenu=1
That one has RAID, SLI, two PCI Express ports, four ram slots, and also has a 5.1 sound card built in.
If you do decide to upgrade your video card, I suggest an NVidia GeForce 9800 GTX. They're about $200 and quite good for gaming.
Don't forget the other things your computer needs:
450 watt PSU or better
cpu fan, chassis fan
thermal grease / silicone paste
Posted on Dec 24, 2008
How to update map
I helped a buddy update his Uniden GPS (Trax350). Simply follow these steps and you should be done.
Uniden's MapTrax350 GPS device accepts voice-command programming and provides detailed audio commands, as well, speaking aloud the map directions that are displayed on its screen. Keeping your Trax350's firmware updated is crucial to keeping it working correctly. Usually, you can go to a company's website and download the latest software, but with Uniden, you must register your product first to access the proper free upgrades. It takes minutes.
Instructions
things you'll need: USB cable
1 Navigate to the link in the Resources section and fill in the required fields. Click on "Register."
2 Turn on your device and connect it to the computer using its USB cable.
3 Log in to the site with the password that was sent to your email address after you registered the device.
4 Choose "Software Upgrades." Select the MapTrax350 device, and the latest firmware upgrade will appear. Click "Download."
5 Select "Save File" and choose a location on your computer to save it to. After it has downloaded, double-click the program icon, select "Run" and follow the prompts to update your Trax350.
Mar 21, 2011 | Uniden GPS
I did not receive any confirmation email
Hi there, Sir, just follow these simple steps.
1. Log in to Facebook 2. Click on Settings 3. Click on Account Settings 4. Click on Notification tab 5. Check the boxes in front of notification which you want as a confirmation
I hope it will help you. Thank you
Regards Fahad
Jan 24, 2010 | Facebook Social Network
I can not register with Facebook. I hace cleared
Hi dear friend, It will not register people who are underage means who are under 18. If you are over 18 years and still getting the same request, try to do the following things
1. Install another browser, i reckon Google Chrome, its fast, reliable and lightweight. 2. Open the browser, go to the website and register.
If you are successful with facebook registration, then try to install antivirus on your system if it is not installed on your system and keep it up to date.
I hope it will help you and do write us about how did you go.
Thank you
Regards Fahad
I want to add my maiden name to my user name
Dear sir, You can only change your username once so before following these steps choose your desire username carefully.
1. Log In to Facebook 2. Move the mouse pointer on Settings 3. Click on Account Settings 4. On the setting tab you will see the user name 5. Click on Change in-front of username 6. Write your desired user name and click on 'check availability' 7. If that name is available than it will accept. 8. Sign out and sign in again
Hope it will help you and solve your problem and thank you so much.
Regards Fahad
Jan 23, 2010 | Facebook Social Network
HI I AM IMRAN FROM PAKISTAN,I HAVE A MOTHERBOARD MADE BY CHINA (SIS 964 PQD2692),I CANT FOUND HIS SOUND&VGA DRIVER,HELP ME SIR
Hello Imran,
You can find the driver at driverguide.com
Its free. You can sign up or use the following
User name : driver2
Password: all
Regards
Uttam
Dec 19, 2009 | Intel Motherboard
My Toshiba satellite Laptop is very slow
i had the same problem with my computer. it may be that you have downloaded too many things. it loads onto your RAM storage, (computer files), and when it gets full, it goes onto the harddrive, (where you access files and things). clear up internet files and anything you don't need. if that is stilll slow upgrade your RAM. it fixed my pc
Jul 27, 2008 | Toshiba Satellite A100-S8111TD Notebook
Web cam problems
sir or middam my name is wali ullah shah and im from pakistan sir i have web cam problum my cam is not conccted sir u hlep me for thats
Jul 12, 2008 | HP Computers & Internet
I need to install drivers for my sansa sandisk
Well I found out that if load the the firmware upgrader on your computer and then
slide the power switch to hold position and then
keeping the select button pressed down
plug it to the computer.
Hold it for say 15 sec and then let go.
In a minute or so the firmware updater will pop up asking you to check for firmware upgrade.
choose the default and follow the prompts
your frown will turn to smile.
Apr 09, 2008 | SanDisk Sansa Clip MP3 Player
64 people viewed this question
k24674
Marvin
Marvin
