Question about LG LRSPC26930 Side by Side Refrigerator
Refirgerator goes to error freeze
Good morning! I am having some issues with my LG LRSPC26930 Side by Side refigerator and am hoping you can help. It continually goes to error freeze about 4 times a day. If somebody wasn't home to reset the breaker, everything would be frozen in the fridge. I have looked online to find out what may be the problem and it said the fan maybe be faulty. I can't find my owner's manual because of a recent move. Can you advise me please? Thanks so much for your time! Janette
Same happened to mine. Got an engineer to check it out and he said the motor was gone. He charged 80 euro for consultation and 170 for the part. Seriously doubt the part cost that much. However, in repairing the fridge when he was gone I noticed tha he had broken the covering over the light in freezer. Am having difficulty getting him back.
Posted on Sep 25, 2007
Error code on my electrolux refirgerator
Good Morning Friend,
I understand you are receiving a T3 error code when you turn the ice maker on your Electrolux refrigerator. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure your ice maker is on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
The unit freezes and does not cool until thawed
This sounds like one or all of these issues:
1. It could be due to lack of good airflow from the cooling coil because your air filter needs to be replaced.
2. You could just have an old compressor that needs to be replaced.
3. You could have a refigerant (freon) leak in your system, causing it to freeze.
The first issue can be fixed by yourself, when you replace your air filter, make sure you take note of the dimensions of the filter so you can buy the correct size. There will be an indicator as to which direction the filter should be facing on the side of the filter itself after you purchase it from your local home improvement store. If you replace your filter and the problem persists, you should call a liscenced professional to come out and assess the issue since the chemicals from the replacement of the compressor and fixing the refigerant leak can be harmful.
Aug 18, 2011 | Goodman CKL60AR60 Air Conditioner
My refigerator is not getting cold but the freezer is working great. I have cleaned out the inside of both but it only helped a little bit.
It could be more than one thing.
1. Its low on freon or has a freon leak. A good sign of this is the freezer will freeze up on the inside around the coils and inside were the food goes. You need a tech that has equipment to recharge the system.
2. The fan that moves the air from the freezer is not working. The top part of the fridge has a vent in the back, feel if there is air flow while the fridge is running. If not have your local parts store get you one. They should have diagram to show how to install it.
3. The Temp control in the refrigerated part is not functioning correctly. Try turning it way down and then adjust up one number or notch every 4 hours until cold ( turning to up to high can cause a freeze up). If there is no change and if its not a freon issue then the circuit needs testing with a multi-meter. (DO NOT TRY UNLESS YOU HAVE EXPERIENCE! Electricity is really dangerous... but you know that. )
Good Luck! I hope this helps you!!
Jun 28, 2011 | Refrigerators
556124 refrigerator. Ice/water disp. shorted out.
Your problem may be with the dispenser electronic control board. This is an issue that should be handled by an appliance service company.
Feb 22, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Samsung refirgerator freezing food.
your damper door is freezing fully open between the freezer and refrige compartment defrost it,then adjust the cold control to make sure its controlling the door position,itsound as if your door seals may be letting in warm air that condenses and freezes on things check this too
Jan 16, 2010 | Refrigerators
Ice maker over flows water into ice hopper than it freezes
Several things can cause this issue.
1. Failed ice maker (overfilling)
You can easily replace the icemaker.
Lg 1 800 243-0000
2. Bad main computer. Or some one over adjusted the fill time on the computer.
3. bad water valve.
Jan 09, 2010 | LG LRSC-26922 Side by Side Refrigerator
Refrigerator side is freezing contents
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Did you get your freezer fixed
dkutlenious1:
Most manufactures recommend 0-5 Degrees in Freezer compartment
and 36-42 Degrees in Refrigerator compartment.
I would also recommend refering to your Use and Care Manuel that you should have received with the Refigerator when purchased.
Jul 15, 2008 | LG LSC26905TT Side by Side Refrigerator
GE Side By side doesn't cool and freexer frosts up
Most common problem on GE's is the defrost heater(s) has gone bad. They are a glass tube and when they go bad the tube will have a burnt or black color to it. A good heater will be clear. I bet that is your problem. Seems to be the problem about 90% of the time on GE not defrosting.
Jun 29, 2008 | GE GSS20IEP Side by Side Refrigerator
LG LRSPC26930 Side by Side Refrigerator Logo
66 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
