Question about OKI MICROLINE 3320 Matrix Printer
Oki 3320 Hi, Ineed your assistant to solve my problem I have OKI 3320 "dot matrix" I have bank form and I need to print the information on that form in specific location "start point " how i can do that easily is their an option on the printer or what .. Note : the bank forms start with different location
  • 22 Answers
There is no easy way. You need to adjust starting position for every form. There is fine feed function and Top Of Form setting procedure, so you can adjust the minimum space between top of porm and first printed string (user's guide explains in details how to do it). But after that you need to decide whether you manually set the start position by rotating the knob or play with your application to adjust margins etc.
Posted on Sep 24, 2009
Oki MICROLINE 3320 All numbers are printed on the invoice where they need to be, but each print yields a line or two of squashed, barely visible numbers (usually at the bottom). Please assist?
Remove the main cover of the printer. There are a few white plastic gears on the right side of the printers engine. You will probably find one tooth missing from one of those gears and a new gear will be needed from OKI. You should be able to get it thru any OKI dealer.
Mar 13, 2017 | The Office Equipment & Supplies
Can we print Courier New font with print quality UTL: Utility in OKI3320 printer
the printer normally prints the font set in the computer as it replicates the document
Mar 30, 2015 | OKI MICROLINE 3320 Matrix Printer
Oki microline 320 form feed
Am afraid the Power Surge (when the power came back on) has damaged the unit and there is no "Reset" to these printers. You would need to replace the control board but as its a power surge there is a reasonable chance that the power supply will have been damaged/weakened and this will lead to a shortened life span of the printer. I would throw it away and replace with new. sorry, ( I am not a salesman either)
Jul 18, 2017 | OKI MICROLINE 321 Turbo Matrix Printer
I've OKI Microline 3320 and printer is printing different characters!! I turned off and then turned on....nothing is working....after turning on..it is still printing.....i turned off and hold the shift...
Alas you cannot clear the ram which is holding your print jobs. This is not a common problem but have seen it before. The only way to resolve it is to replace the main control board.
Sep 28, 2017 | OKI MICROLINE 3320 Matrix Printer
Oki 320ml dot matrix printer pauses while printing and the menu light start to flicker.It resumes printing after a while. Why?
The printhead has some thermisters in and it is either actually overheating or a faulty thermister thinks it is overheating. Either way, a new printhead is required.
Jan 14, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Oki 321 turbo in PPR emulation mode, does a form
Generally the form feed character is sent by your software. Try setting the page length in the printer setup to be the length of one label.
Sep 28, 2009 | OKI MICROLINE 321 Turbo Matrix Printer
How do I adjust the line spacings
Just go to FORMAT and select LINE and SPACING option..there you should select 1.5 spacing....this will solve your problem..
Jun 22, 2009 | OKI MICROLINE 3320 Matrix Printer
Oki microline 3320 doesnt stop in the right place for next invoic
Look on preferences, check if A4 is used for paper layout...
Jun 09, 2009 | OKI MICROLINE 3320 Matrix Printer
I have an OKI ML5590 dot matrix printer. what driver do I use?
get the driver here
http://www.okidata.com/mkt/html/nf/Drivers.html
Apr 02, 2009 | OKI MICROLINE 590 Matrix Printer
OKI MICROLINE 3320 Matrix Printer Logo
465 people viewed this question
Top OKI Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
