Question about ASUS P5B-VM DO Motherboard
ASUS P5B-VM DO motherboard - intermittent audio & intermittent slow performance
A new ASUS P5B-VM DO, running XP Home Edition SP3, Intel Duo Core 1.8 MHz and 1 GB RAM, 3 SATA II drives. Audio is intermittently (80% of the time too bad to listen to) and performance is slow. Can frequently hear lots of disk activity and suspect SATA (IDE) controller drivers are not proper. Although used 2 different driver programs to update most drivers.
Music not listenable and intermittent slow performance.
slink1@cfl.rr.com
  • 3,153 Answers
It may well be some form of virus or spyware.
It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
It can also happen on graphic intensive applications.
You should rule out nasty stuff first.
MBAM !
for a free one its pretty darned good !
From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
May I suggest you download
"hijackthis"
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
Posted on Oct 03, 2009
    Sergeant:
    Champion:
  • 208 Answers
You probably have virus. Run your virus scanner and see if it is clean.
Audio driver for atx in xp
http://support.asus.com/Download.aspx?SLanguage=en&m=P5B-VM
Dec 22, 2012 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Bios problem what are new drivers bios
P5B-E Plus Uses 100% All High-quality Conductive Polymer Capacitors! - Support Intel® next generation 45nm Multi-core CPU
- Intel LGA775 Platform
- Intel® Quad-core CPU Ready
- Intel® Core™2 Extreme / Core™2 Duo Ready
- Intel® P965/ ICH8R
- Dual-channel DDR2 800/667/533
- Fanless Design - Stack Cool 2
- PCI-E Gb LAN/ 8-ch HD Audio
- AI NOS™ / AI Gear / AI Nap
- SATA on the Go/ 1394/ Noise Filter
  • Another option is through the Internet. Launch the utility:
Start > Programs > Asus > ASUSUpdate
Follow the directions.
There is also ASUS EZ Flash.
Make sure that you do have a copy of your current or original BIOS, if you have the CD that came with the MoBo then you are golden.
Sep 20, 2011 | ASUS P5B-E Motherboard
Unknown CPU detected, BIOS update required to unleash its full power after update ... hello, can i run an Intel Core 2 Duo e7500 on an Asus p5vd2-vm se i need help plz
hi
yes u can run Intel Core 2 Duo e7500 on Asus p5vd2-vm socket LGA775 .
spec link's
http://www.asus.com/product.aspx?P_ID=2sYAtam7ng8vCngf
http://ark.intel.com/Product.aspx?id=36503
Mar 22, 2011 | ASUS Computers & Internet
ASUS P5B-E: No Sound after reinstalling XP SP3
THERE IS A SET OF NUMBERS ON THE MOTHERBOARD WHICH ALSO INCLUDES ASUS P5B-E IF YOU GO ON GOOGLE AND ENTER THE MOTHERBOARD NUMBERS YOU SHOULD BE ABLE TO GET THE CORRECT COMPANY & DRIVERS FOR THAT BOARD... GOOD LUCK
Feb 26, 2010 | ASUS P5B-E Motherboard
32 bit or 64 bit?
Here are the motherboard's processor specs >>>>
Intel Quad-core CPU Ready
LGA775 socket for Intel Core 2
Extreme / Core 2 Duo / Pentium D / Pentium 4 / Celeron D
Processors
Compatible with Intel 05B/05A/06 processors
Intel
Hyper-Threading Technology ready
64-Bit Processing Technology
Yes the motherboard can be used with a 32 bit or a 64 bit processor.
Regards..
Nov 13, 2009 | ASUS P5B-VM SE LGA775 Micro-ATX Intel...
Computer won't resume after standby (os: vista)
Make sure all Vista updates have been installed, and check the ASUS website for any bios updates. I believe that motherboard had a known issue with stand bye.
Oct 18, 2009 | ASUS P5B Deluxe Motherboard
My page file hits upto 500mb, is it normal ?
Yes this is normal. It is set under control panel /system icon /advanced tab /settings under performance and then advanced tab again.
Mar 22, 2009 | Intel DG31PR Motherboard
2 Sata HDD not working at a time
In the bios be sure that all the parameters for the SATA drives/devices are AUTO
Dec 11, 2008 | ASUS Motherboard P5B-SE P965 LGA775 Core2...
Pc restart problem
Yes, your mobo Asus P5LD2-VM support CPUs with Conroe-core ("Core 2 Duo"). http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5LD2-VM But for new CPUs strongly recommended use last BIOS version - 1401 from 2007/08/14. http://dlsvr01.asus.com/pub/ASUS/mb/socket775/P5LD2-VM/P5LD2-VM-1401.rar
Oct 03, 2007 | ASUS P5LD2-VM Motherboard
ASUS P5B-VM DO Motherboard Logo
539 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
