Have you made sure that all your phones are connected through microfilters? You may have forgotten to install one, and when you pick up that phone it can knock out your DSL.
if you given parallel connection to phone means u have to use one filter for phone and dsl . in that filter 3 plagin will there 1-line in,2-phone,3-dsl or mdem. give connection to 1-direct wire comming for outside, 3- dsl modem, use 2- give parallel connection. if u not done this means when u pick the phone connection will get dropped. still go to this page http://www.rajasthan.bsnl.co.in/main/trsh.htm or call me 9740575949
whenever the connection drops, is the DSL light blinking? because, it is just normal for the E1 light to blink, but the DSL light should be solid at all times.
It can be a possible issue with the cable or the LAN card, but you still need to have your line checked by Verizon to make sure that it is not a modem or a network issue.
Wellll....since it seemed an impossible task, I tried the next best thing.
I bought a wireless adapter for the other pc and voila! they are on the internet, and I am returning the router.
Westell modem + Verizon DSL w/usb = No connection to router.
i worked for verizon for two years and I encounter this problem many times,to tell you honestly,its not with you internet connection since if you'll notice,while you are connected to the internet and you make a call or call someone,its interrupted... Obviously,its the phone itslelf,the signal comng from the phone is different from the signal of the internet...thats the reason why you need a modem to convert the signal coming from the phone line to make it work for internet,,,what I suggest is you change the DSL plan from the Dry Loop to the regular dsl with the phone...
Rob just studied ur problem.Iam a tech which handles this kind of issue.
I talk to verizon,at&t,bellsouth,qwest daily for such issues.
Well i can suggest u onething u can get the efficient speedstream 4100 series modem which comes with a 1 yr warranty.
And also checkout with verizon clearly abt ur distance from the central office.Bcos might be ur dsl circuit may be not technically feasible
i:e NTF.
For further clarifications plz get back to me.
Have you loked for help on the VersaLink web site?
http://www.westell.com/technical-support...
