Question about Sharp AR-5316 Advanced Digital Imager Copier
Sharp ar-5320e error code U2
Pls help me to find the way to clear this problem, even i press any key useless..... thanks for your help!
    Problem Solver:
  • 13 Answers
Please press these buttons in order #, interrupt,C , interrupt.
when display goes off enter 14 then start button it is ok
Posted on Jan 08, 2009
  • yousef mokhtar Jan 08, 2009
    deeply sory after pressing the buttons please enter 16 not 14 please correct that mistake
In the code "pound star clear star sim 14" what key is sim?
To enter service mode on the AR-M205 you need to press the keys: # key, interrupt key, C key, interrupt key.
then enter 14 & press start.
I assume you are trying to reset an error code.
If you have an error code U2 then enter 16 & press start.
Hope this helps.
Dave.
Oct 13, 2017 | Sharp Office Equipment & Supplies
My sharp copier AR-5320E is displaying error code u2
U2 04 Content EEPROM serial communication
error
Detail Error in communication with
EEPROM
AR-205
Jul 20, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR275 copier error message received is "call for service u2-40" please what can i do to solve the problem?
in order press
* Entering the simulation mode
1) #/P key (program) ON → Asterisk (*) key ON → CLEAR key ON →
Asterisk (*) key ON → Ready for input of a main code of simulation
Simply # * C * and the machine will enter simulation mode.
Then enter the number 16, which is U2 code correction, follow what the screen says, Normally just press start and the machine will reset.
U2 codes are software glitches. A U2 40 is a CRUM fault which is a drum or toner chip problem.
Sim 16 almost always clears them.
May 19, 2011 | Sharp AR-275 Copier
Solution for SHARP AR 5127 error U2-40 call for service
This means that the cartridge's sensor is miscommunicating with the copier memory thus the code U2 -40. You should clean the inner sensor connector and the toner sensor of the spilled toner by low blower. Perform this code ;# , interrupt , C, Interrupt keys in that order and press 16 then Print key and the code will be cleared.
Feb 02, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-285 Error Code ''U2-00'' What does that code mean and can I fix it locally?
A U2-00 is an internal error code from the main processing board's EEPROM (the chip that stores your configuration choices, the copier's serial number, etc.) It can be a faulty EEPROM but most likely the copier took a power hit/glitch and the fault needs to be reset.
To clear the fault make sure the copier is in Copy mode, then press the 'P' key, then the 'Interrupt' key, then the Clear (C) key, then the 'Interrupt' key. This will enter the machine into simulation mode.
Now enter the number 16 and press start. The machine may also ask you to confirm your choice or you may have an 'execute' key on the LCD screen.
Once the fault has been cleared the machine should reboot. If it doesn't, press the 'CA' (clear all) button and the machine should reboot.
If the U2 code persists, you need to call a repair technician to facilitate repairs.
Sep 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
How to fix a sharp ar-m455n error code u2-81
Dear sir; This error code means "scannor memory" problem, don't worry, we can reset it, the procedure as follow;
1, make sure you are in copy mode , then press "p", "*", "clear", "*".
2, enter 16 press start.
3, press "CA" to end simulation.
that's easy, if you need more help, just let me know, good luck.
HAVE A HAPPY HOLIDAY !!!
Dec 20, 2008 | Sharp AR-M455N Copier
Sharp AR-5127, the error code U2-40
U2-40 is a board error, F1-15 is finisher lift motor error.
To reset: #, interrupt, clear, interrupt. (screen should say service mode), enter 16, print, are you sure? , yes.
For the finisher error, follow above procudure, entering 14 instead of 16. if error returns, disconnect the finisher
Nov 26, 2008 | Office Equipment & Supplies
try to cancel it by pressing: #-interrupt-C-interrupt simultaneously, then when the panel goes off input 16 then press the COPY KEY <> The machine will restart automatically. if U2 still remains.. try to replace the mainboard.
Jun 21, 2008 | Sharp AR-5316 Advanced Digital Imager...
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127
PRESS #
PRESS =
PRESS C
PRESS =
TYPE 16
PRESS ENTER BUTTON (the button for making photocopy)
PRESS 'OK' TWICE
Note: be fast in pressing all the buttons.
FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
Apr 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
462 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
