Question about Samsung Yepp YP-F1Z MP3 Player
How to set the clock
I am having a problem setting the clock to my YP-F1 Mp3. I lost the owners manuel and i cant figure out how to set it. Can I get a little help please.
  • 52 Answers
SOURCE: YP-U2J - Need download - Didn't come with CD
In case you have a problem to connect your Samsung YP-U2J Mp3 player, you should update Firmware to get it working. The new Firmware may be downloaded from
CLICK Here to Download : Firmware Update
In case u have WMP 11 and player not working, this error is common after installing Windows Media Player 11
Here is the instruction:
  1. Download the YP-U2J Updater
  2. Remove Mp3 player if you already connected to the USB port
  3. Run the program (You should see something like: Please connect the device)
  4. Hold down the Play button and connect the Mp3 Player to USB port (Hold down the play button while you connect the device, you should see a message (normally after 8 seconds) like: Initializing on YP-U2J Updater program screen)
  5. After you hear the Windows chime "new device found" or the message "Initializing" on YP-U2J Updater, you can now remove your hand from play button.
  6. Check the Format Data Area checkbox (By clicking the yes button, you will lose all of your data in your Mp3 player)
  7. Click the "yes" button
  8. Finally, click on the Start button (takes less than a minute). DO NOT REMOVE YOUR DEVICE
  9. IMPORTANT: After updating the firmware, you MUST disconnect the Mp3 player and turn it on. You will see a 20% message for about 50 seconds and it will be restarted automatically.
Update: Please keep in mind that if you sync your Mp3 player with a computer that has a Windows Media Player 9 or 10, you should do these steps again
Posted on Mar 14, 2008
  • 5 Answers
SOURCE: Samsung YP-K3 ~Lost CD~
u can try downloading the software from download .com it helps a lot
Posted on Apr 27, 2008
  • 8596 Answers
SOURCE: lost cable
or call 1-800-627-4368
Posted on May 23, 2008
  • 3 Answers
SOURCE: lost cable
Try E-bay, available for a couple of dollars from Hong Kong
Posted on Jul 23, 2008
SOURCE: samsung mp3 yp-u3j no driver
download windows media player 11
once you install it follow these steps:
-right click my computer-click properties-click on hardware tab- then click on device manager
- plug in your yp-u3jqby mp3 player
-you should see your mp3 player pop up. double click it. then upgrade drivers.
after endless hours... i finally got it to work. i guess the trick is windows media player 11.
Posted on Sep 12, 2008
  • 65 Answers
SOURCE: I lost the installation cd for my mp3 yp-k5
try to download the software from the manufacturer's website and install
Posted on Sep 26, 2008
0 characters
1 Points
I have a YP-F1. Is it the same as YP-F1X? Can I use the same sw?
I downloaded new version of driver and firmware. The problem seems to be solved.
Thank you very much for your attention
May 07, 2009 | Samsung Yepp YP-F1X MP3 Player
Samsung YP-F1 stuck on 106.0 MHz - Radio Mode
open cover and use paper clip to reset it.
Feb 10, 2009 | Samsung Yepp YP-F1X MP3 Player
Lost cable
Jul 20, 2008 | Samsung YP-U3 MP3 Player
Lost cable
May 23, 2008 | Samsung Yepp YP-F1X MP3 Player
Samsung mp3 player YP-F1 screen diplay won't turn on-even when fully charged
I have samsung yepp YP F1. After full charge, it only appear "loading" and somebody told me to reformat the unit. My question is how do i reformat the unit. thanks - - ronnie
May 09, 2008 | Samsung Yepp YP-F1X MP3 Player
Check the TS guide at the end of the manual for info on the light settings:
Here is the link to the manual for the Samsung YP-F1X:
Oct 12, 2007 | Samsung Yepp YP-F1X MP3 Player
Samsung Yp-U1
hey i lost my set-up cd for yp-u1 and i got a new comp how can i downlaod music into it without the compr econgizing my mp3?
Aug 04, 2007 | Samsung YP-U1 MP3 Player
Samsung YP-C1 Need user manual
ineed driver to YP-C1 i cant find it i lost the cd
Apr 28, 2007 | Samsung YP-C1Z MP3 Player
Samsung Yepp YP-F1Z MP3 Player Logo
16 people viewed this question
Top Samsung MP3 & Digital Media Players Experts
 Mike M
Mike M
Lawrence Oravetz
Are you a Samsung MP3 and Digital Media Player Expert? Answer questions, earn points and help others
