Question about Logitech X-530 Computer Speakers
One speaker is musch louder X-530
I have hooked up my logitech x-530 to my tv through the tv's sound output using a red and white end cable going to the x-530.I only used 3 speakers (front right, front left, and front center) and the subwoofer to save space on the rear speakers. I have noticed that the front right speaker (the main one with the volume control) is much louder than the front center and front left speakers. This makes all the sound go to the right side of the room. Is there any way to fix this problem so that all speakers have equal volume?
    President:
  • 1,179 Answers
On the TV sound options see if there is a balance option. Adjust according to taste if there is that option. Hope this helps.
Posted on Dec 24, 2008
How do i hookup my speakers to my tv
Computer speak usually have a 3.5" headphone plug (just like a pair of headphones). This plug is not native to a TV, they instead usually use RCA plugs (red and white with a solid center post and metal 'sleeve' which makes the connection) these are the most common audio out format for most TVs. You can go to radio shack and buy a 3.5" headphone to RCA adapter which is just a short cable with a female 3.5" plug at one end and two RCA plugs at the other (red and white). This is pretty cheap ~$5 and should get you up and running. You will be going from the label Audio Out ports on your tv through the adapter cable and into your PC speakers.
Mar 12, 2011 | Logitech X-530 5.1 Surround Sound...
How do i connect Logitech X-530 to my TV?
Connect the audio cables (red to red, white to white) from the audio out on the back of your TV to the audio in on your speaker system.
Feb 22, 2010 | Logitech X-530 Computer Speakers
Can my tv play sound through tv and speakers?
There should be an Output in the back of the TV. You will need to get an RCA cable which is the Yellow Red and White cables. Connect the yellow and white cable to the Output in the back of the TV and connect the other end to the Speakers.
Feb 02, 2010 | Insignia IS-LCDTV32 32 in. Television
CAN I HOOK UP Logitech X-530 ON MY LAPTOP
Yes, but you may not get full surround if your soundcard doesn't support it.
Dec 15, 2009 | Logitech X-530 Computer Speakers
Stereo hook up to my 51h84c toshiba
YES YOU CAN DO IT BY YOURSELF. IF YOU HAVE A STEREO, IT SHOULD HAVE AUX INPUT...YOU WILL NEED AUDIO CABLES, RED AND WHITE...CHECK AT THE BACK OF YOUR TV, WHICH SAYS...AUDIO OUT..PLUG THAT TWO CABLES COLOUR CODE MODE...AND THIS END YOUR CABLE GOES IN YOUR STEREO AUX INPUT...ON YOUR STEREO SWITCH TO AUX AND SAME TIME ON YOUR TV....SO YOU WILL BE ABLE TO HEAR SOUND
Oct 14, 2009 | Toshiba 51H84 51" Rear Projection...
Surround sound
your tv might have aux out on the back, I would use that first.
IF NOT, then you will need to use the cable box.  Insert the red and white plugs at the other end of  this cable into the AUDIO IN TV or cable box connectors on the
media center.
Be sure to match red to red and white to white.
3. Use your TV remote control to turn the TV speakers
down to minimum volume.
This prevents the echo effect of audio playing
through both the TV speakers and your 3•2•1®
system speakers.
Apr 09, 2009 | Bose Cinemate Digital Home Theater System...
LOGICTECH X-530
That speaker equipment should've came with an adapter to audio cables
its a rectangle that has 3 ports (orange,black,green) that lead out to 2 ports (red,white) from there u need the audio cables or AV cables
connected the red/white prong to the red/white ports on the adapter.
then connect the other end to the back of the tv where you will c white yellow and red
for dvd player connect it to the white and red ports
dont wry about the yellow 1 that is for video
Oct 18, 2008 | Logitech X-530 Computer Speakers
SAMSUNG
So you want to connect your red and white cables from your satelite box output to the receiver's auxillary inputs or TV inputs.
OR
Red and White from your satelite output to an input on your TV, then another red and white from an output on your TV to the recevier. This way you can have sound from the TV and use the receiver when you want things to get louder. You also need a yellow single connector from the satelite to the TV to carry video. If you are using a coax cable from your satelite to your TV then you are cheaping yourself out of picture quality.
Apr 08, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Logitech x-530 speakers connected to Highlander DVD recorder
YOu need to install the right drivers, for your sound and video card, latest. and Direct X9c.
Jan 13, 2008 | Logitech X-530 Computer Speakers
WIRE ELIMNATION
For the TV:
There are a few possibilities.
1)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the TV Audio OUTPUT to the "Audio In/TV" portion of the HTS (NOTE: Many TV's do not have an Audio OUTPUT).
2)You can connect a red and white AV cable (or the red and white portion of a red, white and yellow cable) from the Audio OUTPUT of your cable or satellite box to the "Audio In/TV" portion of the HTS.
Note: Using a red and white cable may not give you sound on all 5 speakers.
3)Get a digital audio or SPDIF cable and run it from the TV, Cable or Satellite Box's Digital Audio OUT to the "DIGITAL IN" of the HTS. This will give you the best sound quality. When using this (or any of the other) type of connection, press SURR until you get sound from all 5 speakers.
For the Xbox, try hooking a red/white audio cable from the Xbox into the Audio IN/AUX on the back of the HTS, and then switching the source on the home theater to AUX.
Also, the manual can be obtained from www.usasupport.philips.com
-Tha Mp3 Doctor
Jan 06, 2008 | Philips HTS-6500/37 System
Logitech X-530 Computer Speakers Logo
269 people viewed this question
Top Logitech Audio Players & Recorders Experts
Paul
Marvin
Marvin
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
