Question about GE JGBP33SEHSS Stainless Steel Gas Kitchen Range
Broiler not working
The rest of the oven works perfectly, except the broiler. just stopped working, no flames, no nothing. The digital buttons work but nothing happens. Any suggestions? Thanks Natasha
  • Natasha Serafini Apr 27, 2007
    Thanks for taking the time to respond. I will definitely try this.
    Natasha
I agrre with the posibility of a defective ignitor. But, if the ignitor is "clicking" and shuts off there is a flame sensor that usually is the problem. As a Licensed Journeyman, and Retired Contractor in the HVAC&R industries I CANNOT RECOMMEND YOU TRY TO FIX ANY GAS FIRED APPLIANCE OR FURNACE YOURSELF. If your flame sensor is defective it will not let your gas valve open for your broiler section. Find a reputable LICENSED Appliance Repair Service Company in your area (check withe the BBB and see how long they have been "doing Buisness").And have theM do a "FLAT FEE" diagnostic check on it. Dont be affraid to ask him questions and always require they leave any old parts relaced. Make sure that the old part NEVER LEAVES YOUR SIGHT and stay's in your home if he says he has to go out to the truck for the replacement part. Unfortunately consumers are "bilked" for millions every year BY: Small Appliance Repairmen. Get a "Written Estamate of Repair" (REQUIRED BY LAW IN MOST STATES NOW).... THE DIGNOSTIC FEE SHOULD BE INCLUDED IN HIS QUOTE. BEFORE ANY WORK IS STARTED. ALWAYS CONSIDER THE AGE AND OVERALLL CONDITION OF YOUR APPLIANCE BEFORE COMMITING TO FIXING IT. GOOD LUCK ... JOE_REX
Posted on Apr 27, 2007
    President:
  • 878 Answers
Natasha, your broil ignitor probably failed. The oven has two ignitors, one for bake, one for broil. It mounts with 2 quarter inch screws. Part number WB13K0003. Not a hard job to replace. Catriver..post back.
How do I fix broiler that does not burn hot enough to broil. Oven works o.k. Broiler worked last week but now flame is not strong enough.
Make & model? You are talking about flames so I assume it is a gas unit. I would examine the broiler burner, sounds like a problem there.
Nov 29, 2014 | Kitchen Ranges
Kenmore gas range model #790-77471790 oven stopped working...broiler and stove top still work
If the oven has stopped working but the broiler continues to work, it would imply that the bottom heater is broken. When you are using the oven, both the heater for the broiler and the bottom heater are at use. The broiler only uses the top heater.
Elisa Jed ' http://www.atlasappliances.com
Aug 19, 2014 | Kitchen Ranges
Broiler flame becomes weak
check lower broiler for clogs - spider webs etc
Jul 08, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven wont heat broiler wont heat
is this a gas or electric range. If it is gas it sounds like a flame sensor is not working. The oven will try to fire up, but if it does not sence a flame, it will shut off again to keep the range from filling with raw gas. Also the easy one, is the gas turned on?
Aug 31, 2012 | Kitchen Ranges
My broiler stopped working recently. The oven itself works, but the broiler flames are not lighting. I'm thinking it might be a pilot problem.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
fjfj
Sep 26, 2010 | Maytag MGR5780BDS Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Maytag gas oven
if your clock and broiler work then you need to replace the lower oven ignighter remove the oven racks then the bottom plate of the oven its easy then the flame spreader after that you will see a burner bar at the back of that will be the ignighter and just because it glowes dont mean its good just replace it
Jun 13, 2008 | Maytag MGR5751AD Gas Kitchen Range
Broiler not workig
The flame maybe not enough try to clean the gas nozzle at back potion of the oven , look for small wire to clean the clug by dust and rust , after cleaning test the flame , the burner will increase in flame .
Dec 24, 2007 | Amana ARGS7650SS Gas Kitchen Range
Broiler Still Not Working
does the board control both ignitors and if so your right the ignition board is bad.
Aug 27, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE JGBP33SEHSS Stainless Steel Gas Kitchen Range Logo
129 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
