Question about Philips 43PP9202 43" Rear Projection Television
Hi there, i have an old Philips 43pp925/79 rear projection tv. A few weeks ago convergence ic went bad, so i replaced them both and i replaced 6 resistors. Now there is no bending on the screen but the color is all over the screen. I tried to align them from menu but i can't move red or blue dots. i dont know where i went wrong. it looks like 3D.
  • 6 more comments
  • adil_hoss713 Dec 24, 2008
    Thank you for reply so quick. Yes i went with the same part number which is STK 392-110. I have the service manual and i was studying it and trying to fix it. but i
    think i have to some fix error like double window. which showed in SAM mode. and i also think i gotta fix geometry thingy which is i have no idea about it. need help badly. Thank you
  • adil_hoss713 Dec 25, 2008
    Hi, i went through the service menu. but Couldn,t find how to fix the convergence. the red and blue dots are not moving at all. someone help please. thanks.
    Thanks ladywin, i tried that. but nuh, its not working i mean the R G B dots are not moving at all. is there like something wrong mechanically?
  • adil_hoss713 Dec 26, 2008
    yeah. i can go to the service menu. but cant move up or down or right or left.
    i mean i can go to the service menu. then i can go to menu. my navigation buttons works but when i go to convergence menu i cant move red or blue dots, not by my remote or by my tv key board. it will be very helpful if you can help me because finding same signal board is very hard. Thank you.
  • adil_hoss713 Dec 28, 2008
    hi there, i tried it but there nothing happened. so, do you reckon i should change my whole small signal board. if i have to can you suggest me where i can one online. thank you.
  • adil_hoss713 Dec 31, 2008
    hi there, i was checking and now suddenly my volume isn't working anymore. first i cant change my convergence and now sound. is it small signal board problem??? Where i can find ssb online. i was looking for it but cant find anywhere. a little help will be appreciated. thanks.
  • miss-capulet Mar 08, 2009
    hi there,
    i have a phillips 43PP925/79 and the screen is bent as well as the screen is red and blue i have tried to tune the red and blue converge but it does not move up,down or side to side
    please help,
  • Philips Master
  • 5,138 Answers
You will have to go into Service Menu to realine convergences and What was the STKs numbers you replaced/ and did you go with same part number?I think i have service code for this set will have to look thur my files.
Posted on Dec 24, 2008
  • 1 more comment
  • ladywinn
    ladywinn Dec 25, 2008
    Try this Code there is 4 Different Methods to Enter Service Menu for [alinements] Turn set on ,using hand unit Press 0 6 2 5 9 6 ,then press Menu----- Press menu to change adjustments for R,G,B
  • ladywinn
    ladywinn Dec 26, 2008
    Are you able to enter service menu and if so are you saying you have no control on adjusting up&down back & forward ?
  • ladywinn
    With TV on Press Menu ,While menu is up Press 0-6-1-5-9-6 or 0-6-1-5-9-7 using arrows Left/Right to select up/down to adjust. try these and see if it will let you adjust.
Several years ago we purchased a Philips 60" Rear
It seems problem with convergence output section of tv and convergence output ICs need to be replaced by professional because it requires soldering work with proper tools.
Please call local tv repair shop to get tv repaired.
Thanks.
Jan 18, 2011 | Philips 60PP9202 60" Rear Projection...
Can't correct my red blue convergence manually or by using factory preset...the unit is 7 years old, is my picture tube bad?
You have bad convergence ICs. There are 2 ICs in the convergence circuit, one is for the Blue the other is for the Red. You can buy 2 ICs for under $40.00. Replacing these ICs require soldering and desoldering skills. Sometime, the resistors in the convergence circuit go bad also. Be very careful, there is a very high voltage in a CRT projection TV the voltage is over 30,000 volts.
Best of Luck
Sabre
Feb 23, 2010 | Philips 60PP9202 60" Rear Projection...
HAVE A JVC AV-56WP30 REAR PROJECTION TV THAT THE PICTURE APPEARS IN A BOWED SHAPE. THIS TV WAS JUST REPAIRED FOR THIS PROBLEM ONE WEEK AGO AND IN 100 MILE DRIVE TO PUT IN APARTMENT IT IS AGAIN NOT WORKING....
The convergence is dead,Must replaced Convergence ICs and resistors.Tell the shop to repair it again.They probally didn't replaced the ICs or resistors.This problems can't come back about a week,at 6 months i can understand.
Jan 11, 2010 | Televison & Video
My hcp4752 started smelling hot now the colors are
It looks like you have a problem on your convergence panel. Look for burned resistors near the STK-* IC's. One or more of the STK-* IC's may be bad. When the resistors get hot they smell but so do the IC's. You can replace the bad parts or you should be able to replace the entire panel then go thru a convergence alignment.
Jun 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
Convergence problem
Some how instead of posting this to another persons problem it posted here.Hmm Oh well you said you replaced STKs what was their numbers and you may need Service Code also to Realine convergences
Dec 24, 2008 | Philips 43PP9202 43" Rear Projection...
Convergence problem wiht jvc av 48wp30
Bad chips...There are a ton of cheap fakes out there....Or bad resistor...
Projection TV sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Example Photo:
Problem #2 CRT Fluid has clouded over.
Symptoms
  • Dull Video, Washed out
  • White/Bright looking video
  • Halos around objects
  • Red/Orange looking
Example Photo:
You can see more examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 29, 2008 | JVC AV-48WP30 48" Rear Projection...
Problem with Colors Seperating
can the remote move the clors in all 4 directions? If not the convergence ICs need to be replaced. Also check the resistors that power the ICs they are located right next to the ICs
Mar 19, 2008 | Philips 60PP9202 60" Rear Projection...
Phillips 55PP9401 Convergence Problem
STK392-110 convergence IC's upgrade to STK394-160.....
I use Hitachi brand part # CZ 01341 ... change both.......
Check for dis-colored resistor (s) = replace with exact value...
Please respond............T.
Aug 12, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 43PP9202 43" Rear Projection Television Logo
166 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
