Question about Saeco Magic De Luxe Espresso Machine
Water leaking under the tank
Intermetinly water leaks fom under tank
  • 1 more comment
  • jpaulallen Jan 04, 2009
    Water leaks internally from my same machine. I cannot see where the leak originates. I have to take the machine apart to get to the hoses for inspection.
    Anyone have a technical repair guide on how to take the machine apart and put it back together successfully?
  • upnorthnana Mar 08, 2009
    Not only is ours leaking a LOT of water all of a sudden, but it is also shutting off the circuit breaker in the kitchen. Whatever hose is leaking must be near the electrical parts. Has anyone found a schematic of this coffee maker so we can take it apart and look for hoses?
  • jpaulallen May 11, 2010
    Thanks for the info. The water leaks from my machine towards the front, when it is pumping water while making the espresso shot itself.
    I do not recall if it leaks during the steaming operation.
    I looked inside from the vents in the back, and it looks like there is small plastic tubing that runs to the front of the machine, in the area of the leak.
    I am concerned that if I start to take the machine apart without a technical diagram, I will never get it back together.
    It still steams and makes espresso.
    Thanks
    Problem Solver:
  • 8 Answers
If the water is coming from under the cold water tank on the back of the machine it probably the o-ring seal in the grey machine recepticle which is visable when you remove the tank for filling. This seals the tank to the machine body and over time can leak (mine has!!). You can get them from Gaggia UK in Halifax
Posted on Jan 09, 2009
Water leaks under portable air con unit
Look for a crack on the water tank or a dried up gasket on the tank. Loose hose clamps can allow a leak as well.
Jan 04, 2014 | Heating & Cooling
2004 bmw 325ci water leaking under expansion tank
remove the expansion tank and have a look at the seams those tanks have a habit of distorting and start leaking
Feb 07, 2013 | 2004 BMW 325i
Leaking water tank on Insinkerator hot water dispenser
Jan 2013
1) If the tank is leaking, then Replace with new dispenser.
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
2) Add comment and attach photo of leak.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 23, 2013 | Emerson InSinkErator W-152 Hot Water...
My Rheem Electric water heater is leaking from around the side of the tank above the lower element.I can not find the spot exactly. What can I do to find the spot where the leak is coming from?
You can put hand on side of tank and feel for warm spot.
Tank is most likely rusted out and needs replacement.
If tank leak is welded, the rest of tank is still rusting and can rupture under pressure.
Open following links for troubleshoot walk-thru.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/Emergency-steps-for-leaking-water-heater.html
Jul 31, 2011 | Rheem Water Heaters
Leaking from inside the tank this is a rheem GN-100-200
You posted under gas water heaters.
If water heater tank is leaking, it will need to be replaced.
If you have electric water heater, check if water is leaking around element.
Open following link for a troubleshoot checklist:
http://waterheatertimer.org/Water-heater-is-leaking.html
Also it is important to protect yourself from ruptured tank:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 23, 2011 | Rheem Tank Water Heater G100-200, 100...
Is my water heater still under warranty leaking water on top of heater and out from bottom and from plate
1) If water heater is leaking, I suggest you protect yourself first.
2) You have to do some work to find out if tank is under warranty.
-Contact manufacturer: http://waterheatertimer.org/Water-heater-manufacturers.html
-Contact installer: If plumber installed heater, then installer backs warranty for some manufacturers. If you installed heater, then warranty is less or void
-Look at paperwork and manual that came with water heater and read about warranty coverage
-Look at markings on tank to see if tank is 6 year, 15 year etc
-Warranty is based on date of manufacture: To find date of water heater, look at serial number located on label on side of tank:
Open link below for serial number decoder by manufacturer.
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) If tank is older than 6 years, and tank label shows this is a 6-year tank, then tank is no longer under warranty.
If you have a lifetime tank, then warranty is in effect, so contact manufacturer.
Open following link to see troubleshoot checklist for leaking water heater:
Other things to consider:
-If tank rusted out after a few years and installer did not install a jumper wire between hot and cold pipes, then tank warranty will probably not cover tank.
-If tank rusted out and you have water softener, and did not inspect anode rod or maintain water heater, then you did not read manual or maintain heater, and warranty might not cover problem.
-I suggest you read water heater manual cover to cover so water heater will not start leaking.
Other useful links:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Feb 12, 2011 | Reliance Water Heaters
It looks that water is leaking from the - Culligan water softner
Look down the tube (where the float assembly is) there should only be about 10-12" of water in there. For water to reach the brine tank over flow the tank would have to be 3/4 of water. Brine tanks can develop leaks over time if they were set on uneven ground or if any rocks or debris are under it. If there is no evidence of water running down the side of the brine tank this is the most likely cause. Also if it has been leaking for some time there will salt buildup around the brine tank. Check the water softener for any leaks also. At times a small leak from the softener will find it's way over to the brine tank and collect around the bottom of it.
RJ
Jun 14, 2010 | Culligan Sediment Water Filter
Water leaking in basement because there is a small leak in current expansion tank. can we stop water from leaking tonight and still have water to house? and are these tanks easy to replace?
For tonight I would set a bucket under it to cathc the water from the leak. The tank will not start to leak much worse in the next few hours...
And, no it is not hard to change the tank. Just messy....:-) Becareful though as the tank may be heavy if the bladder has ruptured...
Simply use two wrenches and unscrew the tank and then tape or dope the threads and screw the new tank back on...just that simple...make sure you get a fresh water exspansion tank and not a heating one...
heatman101
Mar 30, 2010 | Amtrol ST-5-C THERM-X-TROL ASME Expansion...
Water leaking from underneath water tank.
I rang Saeco service centre about my leaking water tank and they posted me a new tank - no questions or need to return the faulty item. I believe there may be a bad batch of tanks which leak because of faulty valves.
Mar 24, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Water leak fom winderscreen wash container not input seal ,front area leak
there is an overflow on the tank when you top it up to the top it will overflow and look like a leak.
Sep 26, 2008 | 1998 Jaguar XK8
Saeco Magic De Luxe Espresso Machine Logo
345 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
