Small home network cable modem connected to a fs108 three comps and 2 gameing systems connected to the fs108, prob is i can get one system at a time to get the internet, i can access all systems on the local network but only one comp to the net, the other comps are not getting a ip address from the dhcp windows is assigning it automaticaly ex. comp 1 that is on the net ip-63.162.28.1 Comp 2-169.254.121.148 if i disconnect the comp that has internet access and reboot the modem and switch one of the other comps or gameing system get the net and not the others
possible issue with freequent connection loss when going over 2 comp on a network are possible issues of collisions on the network meaning that sometimes more often then not, it is possible for two comp to end up recieving same ip address fr modem.
solution: first find out ip range supplied by the router in modem. then statically assign ip address to each comp
this is done by going into tcp/ip properties of either nic or wireless card and set to use following ex
NOTE: IP RANGE USUALLY LAST SET OF NUMBERS IN IP ADDRESSING TIPPICAL RANGE IS BETWEEN 10 TO 99
ip address: 192.168.2.12 (static ip address for computer)
subnetmask: 255.255.255.254 (generic subnetmask)
default gateway: 192.168.2.1 (ip address of router)
