Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water dripping inside refrigerator
Water problem not associated with ice maker
Water dripping ocassionally from center vent in refrigerator below the ice box. Maybe related to icebox defrost?
  • 71 Answers
The defoost drain is cloged the drain inlet is located in the freezer behind the back wall under the coils. to clear the drain remove the back wall in the freezer and clear the ice underneth the coils then use hot water to clear the drain inlet, I use a garden sprayer to spray hot water.
Posted on Dec 25, 2008
What causes my ice maker to drip water?
HI,
This could be either the ice maker is old and the finish inside has depleted, the water valve is going bad or you had a jammed ice cube and now it overfilled. Many different reason this could happen. Does the ice cubes stick together with a bridge? Is the drip coming from the ice maker head unit? How is the ice in the pan its stored in, stuck together? In the pan, has the ice glaciered together? Need more information please. Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 09, 2014 | Kenmore Top Freezer Refrigerator
My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
Good day,
No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
Very common problem.
Thank you for using FixYa
Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Water driping inside from ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hollow ice cubes. Ocassional clunk sound and
Hollow cubes indicate the water inlet valve is defective ( not letting enough water into the ice maker ) . Replace the valve behind the refrig ( the piece the wall water lne connects to on the refrig ) . Do not try adjusting the water on the ice maker itself , even if someone else suggests it , as this adjustment is factory preset .
Sep 25, 2009 | Amana Refrigerators
Water coming out of the inside bCK OF MY FRIDGE
your drain hole is clogged needs to be thawed and cleaned out
Mar 18, 2009 | Refrigerators
Ice maker won't stop dripping
If your i/m is dripping you most likely have a crack in the ice mold, you should replace the ice maker.
Jan 01, 2009 | Sub-Zero 650 / O Bottom Freezer...
Water leaks from inside refrigerator
could be ice is forming at the vents already.
even though it is a frost less refrigerator, in some instances, you may want to defrost it manually or leave the door open for 1 day just to be sure that every ice in the fridge has melted. then plug it back in and observe it.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Refrigerators
Dripping water from a ge fridge with a ice and water dispenser. why is the water spout dripping?
hello ghreay..
do u've Water on floor outside of refrigerator? plz do the follwing..
do u've Water inside the refrigerator? plz do the follwing..
  • Clean the drain tube
  • If you have an ice-maker, check refrigerator and ice-maker for level.
thank you for using fixya..
Sep 27, 2008 | GE Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
314 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
