Question about Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118)
Matshita DVD-RAM UJ-851S
Problem device is Matshita DVD-RAM UJ-851S. it disappeared from 'My Computer'. does not autoplay either. tried to update driver in Device Manager but came up with Code 39 and said that i already had the updated drivers for this device.
i have an HP Pavilion dv2000 laptop running on Vista.
Posted by rahilaaz on Aug 25, 2008
  • 1 more comment
  • Anonymous Apr 02, 2009
    wont play a dvd, says device cannnot start. what do i do
  • Anonymous Apr 11, 2009
    The Device can´t read any discs
  • Anonymous Apr 19, 2009
    Same problem Matshita DVD-RAM UJ-851S. Been trying to work out for 2 solid days. There are so many complaints on this "NON" dvd playing drive I now no why it is appropriately named maSHITa. I cannot believe HP continues the use if this *&^%(*. They want more money to fix above the warranty. I will just buy another dvd drive that's dependable. Recommend you do the same.
    Sergeant:
    Champion:
  • 452 Answers
Here's the fix
http://msbin.com/kb/entry/53/
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
4. On the File menu, click Export.
5. In the File name box, type savedkey, and then click Save.
6. Click the REG_MULTI_SZ data type UpperFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
Note If this data type is missing, go to Method 2.
7. Click the REG_MULTI_SZ data type LowerFilters, and then click Delete on the Edit menu. When you are prompted to confirm the deletion, click Yes.
8. Quit Registry Editor, and then restart the computer.
Posted on May 20, 2010
My HP Pavillion dv6560oe can not install the driver for the MATSHITA DVD-RAM UJ-851s ATA device. The device has stopped functionning (code.10)
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
http://welcome.hp.com/country/au/en/cs/support.html
Apr 26, 2011 | HP Computers & Internet
Busco matshita dvd-ram uj-840s driver para el windows xp. Alguien me puede ayudar? No lo encuentro en ninguna pagina. En la pagina oficial solamente existe para el windows 2000. Gracias.
Not sure of your question; I read only English.
There are many sources for the drivers for your DVD; many would liek you to downlaod and use their driver update programs. An advantage is if there is ever an additional update the program will let you know. Here are two examples that you might consider as sources for an updated driver:
http://driver-helper.org/matshita-drivers/matshita5/matshita-dvd-ram-uj-840s-ata-device-driver-download/
http://www.driverboost.com/lp/drivers/update/Matshita-System-Drivers.php
Dec 28, 2010 | HP Computers & Internet
Uninstalled matshita dvd-ram uj-8505 ata device
Go to Control Panel, Add Hardware and Windows should do it for you.
If you are PC literate go to Start click on it go to My Computer nad right click on ot go to Hardware and click on it go to Device Manager and click on that scroll down to CD/DVD and click on that select the DVD unit and select update driver
Jan 14, 2010 | Sony VAIO VGN-N365E/B Notebook
Matshita dvd-ram uj-851s ata device vista
Foolw the guide below, this will edit the registry, making the device visible and useful again.....
Windows Vista
1. Click Start
and then click All Programs.
2. Click Accessories, and then click Run.
3. Type regedit, and then click OK.
If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
4. In the navigation pane, locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
5.
6. In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry. To do this, go to step 8.
7. On the Edit menu, click Delete.
8. When you are prompted to confirm the deletion, click Yes.
9. In the right pane, click LowerFilters.
10. On the Edit menu, click Delete.
11. When you are prompted to confirm the deletion, click Yes.
12. Exit Registry Editor.
13. Restart the computer.
Oct 16, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Cant burn cd - error 4450
So first off, you have a problem with your registry. This is a problem seeing as you are not an administrator and the only way to fix the registry is to be an admin. So if and/or when you are and administrator simply download the RegCure registry repair tool. also get a SpyWare scan as well and update all your system drivers. That should do the trick or just any old program off the internet that cleans out your registry really. If you want to edit the registry manually just hit start>run and type in regedit and mess with it there. unless you know what you're doing i wouldn't recommend messing with the registry though.
Jun 14, 2009 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Cannot burn CD or DVD
In the Device Manager, right-click on the DVD drive and select the Uninstall option. Reboot the computer so it will re-detect the drive, reinstall the proper drivers and reset its configuration information. Then try burning the disc again.
Apr 09, 2009 | HP Pavilion dv6326us Laptop
MATSHITA DVD RAM UJ-850S Device Not Even Shown
Try a Google search for the driver. I got my printer driver that way. Prints just fine.
Feb 14, 2009 | Computers & Internet
Does not reccognize dvd/cd drive
go to control panel, classic view, system, hardware, device manager, dvd, cdrom devices and go to the cddrive in the drop down menu and uninstall it. restart your computer and it will reinstall the cd drive if you have any more questions, please email me at meanness628@aim.com
Jun 22, 2008 | HP Pavilion dv9000z Notebook
Philips SAA7130 TV Tuner/FM Radio/Video PCI Capture Card (683728017118) Logo
493 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
