Question about KitchenAid KGSS907SSS Gas Kitchen Range
Ignitor not glowing
I have checked the thrmst - fix on back and it seems fine. Both the broil and bake ignitors do not glow.
SOURCE: 8 year old kitchenaid gas range nom fire in the oven
I went to the kitchenaid web site for parts and found a trouble shooting section. I read about how a electronic glow coil works and discovered that mine was just old and did not reach the right voltage to open the gas flow valve.
Posted on Feb 21, 2008
SOURCE: Oven Won't Ignite
http://www.appliance411.com/faq/gas_range_ignition_systems.shtml#glow
Posted on Jul 31, 2008
  • 464 Answers
SOURCE: Gas oven does not work at all
yes it definately sounds like you need to replace the bake ignitor. it needs to glow white in colour to ignite. if it is orange it is too weak.
Posted on Nov 07, 2009
Testimonial: "Sassy6, THANKS A LOT! I will try to buy the part and install it by myself then. If you think that I cannot for some reason, please, let me know. "
heatman101
  • 43501 Answers
SOURCE: KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 15, 2010
oldTech2332
  • 2341 Answers
SOURCE: I havef a KitchenAid Gas Range Model KGSS907...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Posted on Aug 27, 2011
Flow plug
even though the ignitor seems to glow bright orange,it still maybe weak,as in not enough current to open the gas valve,an easy test is to just swap out or interchange the broiler ignitor and bake ignitors and see if this takes care of your issue on the lower bake side as most units use the identical ignitor for each upper and lower manifolds and the gas valve supplies both the bake and broiler manifolds depending on which you choose to use bake or broil
May 28, 2012 | Jenn-Air Chef Gas Oven Range Ignitor Flat...
Hg2415uc siemens oven not heating
The ignitor, or glow coil, has to draw something like 3.2 amps for the safety gas valve to open to let gas in. With that said, just because the ignitor is glowing, doesn't mean that its working properly. I've had to change one safety valve in a total of 13 years of doing this, so I'm thinking the ignitor on your machine is bad.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 28, 2012 | Siemens HG2415UC Stainless Steel Gas...
I have a Kitchenaid KGBS276X double wall oven. The botton oven works fine. The top oven will start when it's in the broil position, but as soon as I turn down the heat setting it cuts out and stops. ...
so you're saying you have no bake,correct.you have a broil ignitor and a bake ignitor,the broil only has one setting and that's broil,all the other settings are for bake.i looked up the ignitor on the sears site,it costs 189 bucks.it cross refrences to part number 12400035 and this ignitor will work and it's 62 bucks,change out the bake ignitor and you should be fine,you can check it with a meter or turn on the oven and see if the ignitor even glows,it turns red when it's on but even if it glows this doesn't mean it's good,it opens the gas valve by amps,3.5 amps but i would start with the ignitor,it should fire up in around 40 seconds or shorter,if it's more than a minute the ignitor is no good.let me know what you find,unplug the oven before you change out the ignitor
Sep 18, 2010 | KitchenAid Kitchen Ranges
The Bake ignitor in our Amana Gas Range (model #ACF3375AW) recently began to only work intermittently. Now it doesn't work at all. The Broil ignitor works fine. Any ideas? Thanks! Dana - Minneapolis
Hi Dana from Minneapolis...you need a new Bake ignitor, which is also called a glow coil. When it's working properly it glows a white hot colour and as it wears out it will glow an orange colour and needs to be replaced, this is why it began failing and then quit altogether. This is a part that requires an authorized gas technician to install for you. Good Luck.
Jan 26, 2010 | Amana Kitchen Ranges
Bake does not work
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Dec 11, 2009 | GE Profile JGSP48 Gas Kitchen Range
I have a JGBP30 gas range and the oven does not. Someone checked it and said the main control is bad. Is there a manuel that I could get or is there any way I could check it, before ordering a new...
Does the oven ignitor "glow" when turned on but no flame appears? does this model have an actual broil burner ? or does it just have a broil drawer at the bottom ? If it has a broil burner up top of the oven, does it ignite ? It could be the clock/timer, but rarely. If the "bake" ignitor glows, but the burner doesn't ignite, or ignites slowly and/or a "sputtering" flame, replacing the bake ignitor should solve the problem.
good luck
Sep 26, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Kenmore Oven
PS go to searspartsdirect.com, type in your model number for the exact replacement part number.
Oct 27, 2008 | Stoves 500SIDL Gas Kitchen Range
Oven will not heat up.
eerb, most likley your ignitor failed. When you turn the oven on to bake you should hear a relay click on the electronic control (clock). You can do a couple of things here. If you have a ohmmeter the ignitor should ohm out at between 50 and 150 ohms. You can physically swap out the bake and broil ignitors to see if the ignitor comes on in bake. Or you can swap the bake and broil wires on the board. They should be marked BA and BR. This way when you turn on bake, the broil ignitor should glow and verify you have power going to it. Carefull when testing, be sure to kill power to the range before any changes. Catriver...post back
Dec 12, 2006 | GE JGBP26 Gas Kitchen Range
KitchenAid KGSS907SSS Gas Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
