Question about Nikon Coolpix 8800 Digital Camera
Problem with the date and time settings
Thing is that when i turn on the camera it goes straight to the date and time menu.
its says on the screen; set date and time. and at the bottom of that it has the option of choosing yes or no.
problem is that it wont let me move to the next step, its like its frozen or something. but when i take the 4g memory out and in it beeps, so it cant be frozen. i have no clue what to do
please help!
  • 423 Answers
Hi Alonzo,
Change the mode setting to Setup. Scroll down to the date menu and set your date and time. That screen should not pop up after that. UNLESS your date battery is toast. If that't the case, replace it.
Let me know if you still have a problem and I'll help you take care of it if possible. Or, if your satisfied, you can rate my solution a fixya.
Rob
Posted on Feb 27, 2009
Can not set date on kadak easyshare c330
The camera should be able to have its date and time set through the menu and it should hold the date if you switch batteries. If it doesn't then the internal battery may have to be changed by a kodak service center.
The camera screen displays "Date/Time have been reset." What should I do?
This message appears if:
  • this is the first time that you have turned on your camera.
  • the battery has been removed for an extended period of time.
  • the battery is exhausted.
To set the date and time:
  1. Press the Menu button.
  2. Use the arrows to:
    1. Select the Setup menu.
    2. Select the Date & Time feature.
    3. Set the date and time.
  3. When you are finished, press the OK button.
For more information, see your camera user's guide for your camera
Dec 18, 2010 | Kodak EasyShare C330 Digital Camera
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
Cannot turn on date stamp
The date stamp only works in "Postcard" resolution. Press the Func Set button, then scroll down to the bottom to select postcard resolution.
Then press the menu button. The date time stamp selection should now work. Simply turn it on.
Oct 03, 2009 | Canon PowerShot A620 Digital Camera
How to re-set date in the camera?
turn on your camera and go to menu. top of the screen you will see 3 camera tabs. choose the 3rd screen with the wrench on the camera. this will take you to what you need to change the date. scroll down the screen till you see 'Date & Time', then open it up by pressing the 'ok' button. You should be seeing a screen that asks you to set format. continue to the month, date and year, then time after you have entered your settings, press ok. after your done, press menu button to return to the viewing screen for picure taking. your camera may go to a blank (black) screen while no action is taken. If this happens, just press your menu key and return to the 3rd tab and proceed with the instructions.
Aug 23, 2009 | Kodak EasyShare M863 Digital Camera
Date Stamping
I have just discovered how to correct this - you have to have the resolution set to min postcard setting in order to be able to date stamp your pictures for some reason...
Apr 07, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Can't get the Date off the Pictures
First you have to go to the set up menu and set the correct time and date, then you can go back to the settings and select OFF for time and date. If you do not set the correct time and date , that default date stays in the picture.
Jan 21, 2009 | Polaroid i830 Digital Camera
Sony DSC-W150 power on keeps going to set date/time
The date and time settings are displayed after turning on the camera. Solution
sp.gif sp.gif It is normal for the camera to lose time and date settings if the internal battery is left uncharged for an extended period of time; some cameras will default to the time-setting screen when turned on if this happens. Follow the steps below to resolve this issue.
  1. Turn off the camera.
  2. Do one of the following:
    • Insert a fully-charged battery pack into the camera.
    • If the camera is supplied with an AC power adapter, plug the adapter into a working electrical outlet and then connect it to the camera.
  3. Allow the internal battery that retains the time and date information to charge for at least 90 minutes.
  4. After enough time has elapsed to sufficiently charge the internal battery, turn on the camera.
  5. Set the time and date.
  6. Turn off the camera for 30 seconds.
  7. Turn on the camera again.
  8. Check to see if the date and time have been saved.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 23, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Cannot set the Time/Date
Setting the Date and Time The date/time needs to be set if/when: Camera is turned on for the first time. Camera is turned on after leaving ViviCam X60 without the battery for an extended period of time. When the date and time information is not displayed on the LCD monitor, follow these steps to set the correct date and time. 1. Slide the mode switch to [replay ], and press the MENU button. 2. Select [Setup2] with the LEFT ARROW button. 3. Select [Date/Time] with the UP ARROW / DOWN ARROW buttons, and press the SET button. The Date/Time setting screen will be displayed:[Setup] [Format], [On/Off]. 4. Select [Setup] with UP ARROW / DOWN ARROW buttons,and press the SET button. Select the item’s field with theLEFT ARROW / RIGHT ARROW buttons and adjust the value for the date and time with the UP ARROW / DOWN ARROW buttons. The date and time is displayed as the format you set. The time is displayed in 24-hour format. After confirming all settings are correct, press the SET button. The setting will be stored and the screen will return to the Setup2 menu.
Jul 05, 2008 | Cameras
Cant get onto the menu screen
I finally figured it out!!! There is a button on the right-hand side of the camera, which switches it from normal mode to simple mode. Just press the button and everything goes back to the way it was...
Feb 24, 2008 | Olympus Stylus 730 Digital Camera
Blurry Pics and not able to set date/time
You can only set the date stamp in the “Post Card” resolution mode. Hit the “function” button, go down to the resolution selection (L, M, S, W, Postcard, etc.). Pick the “Post Card” setting. Hit the “menu” button and the “date stamp” menu will be active
May 07, 2007 | Canon PowerShot SD600 Digital Camera
Nikon Coolpix 8800 Digital Camera Logo
226 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
