Question about Samsung LE32R73BD 32 in. HD-Ready LCD Television
TV doesn't turn on. All power sources working.
TV does not respond. No light. No noise. Checked all connections.
  • 335 Answers
Check the main power cord for proper fit from the wall too the tv. Make sure the cord is well fitted in the outlet and the tv. If the connection is in standing and there's ac voltage coming from the outlet.......then it
may be a blown fuse or a dead power supply circuit with-in the tv. If so, the tv needs to be serviced.
Posted on Jan 04, 2009
My tv has ben un plugged for 3 months and now it will not turn on. What should I try?
How/where was it stored? Are there buttons on the tv itself? Do you have any LED lights on at all? Does the tv make any clicking noises when you plug it in?
Dec 16, 2014 | Sony Kdl-32bx310
My LG Flatron rear projection TV won't turn on. The on/off power button is not turning the TV on. There is no click sound and the red light doesn't come on. The TV is connected to mains power and ther
tried with other ac outlet doesn't work?. if still won't turn on, at this time you will need to remove the rear cover to gain access the internal part. since your tv doesn't have any power indicator, the first place to be checked will be the power supply board this is where the power connector cord is connected. now look for a blown fuse replaced with the same rating. but take note before you replaced the bad fuse you must need to have component testing in the power supply board which the cause of blown of the fuse. like shorted bridge diode, open resistance and defective mosfet or bad regulator ic.at this time you will need a device called digital tester to check weather the parts need replacement.hope this can help good luck.
Nov 02, 2012 | Televison & Video
I have a pth5498 when u plug it in tv doesn't come on just makes clicking noise no tubes light up or anything just sound and front power light....
There could be many items that can cause that symptom. However I always assume convergence on any rear projection which can easily be checked by unplugging the convergence amp board and then plugging in the set and press power , if the set powers up turn it back off, and you will know the convergence ICs and associated resistors on that board have failed. Although its easier to replace the board unless you have good soldering skills. I am pasting a pic of the board which is suspended above the main chassis just mark the wires then unplug the set from the wall first, but then unplug the wires from that board and then try powering up the set.if you need further assistance , respond to this same post slinteriors_21.jpg
Aug 12, 2011 | Akai PTH5498 54" Rear Projection...
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
Green light is on ...white noise sound but no picture
This TV finds the connected input sources
automatically for AV1, AV2 and Component 1-
2. It is presumed that RGB and HDMI/DVI
sources are connected.
Check your setup to see if the audio is turn off but if you have a clear picture you should have sound.
Time to call a TV Tech if you are not going to repair the unit.
Jul 11, 2009 | LG 42PC3D 42 in. Plasma Television
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Jan 25, 2008 | RCA HD56W58 56" TV
Samsung LE32R73BD 32 in. HD-Ready LCD Television Logo
185 people viewed this question
Jerry Greenberg
Jerry Greenberg
