Question about JVC DR-MV5S DVD Recorder/VCR
Very low Audio and no LED Display
I received a static electricity shock from my recorder while removing a cd. Now it no longer has an LED Display and the audio signal is very low. HELP!!
  • 126 Answers
Get a refund. This fault is a can of worms mate. A road you do not want to go down
Posted on Dec 25, 2008
Why will Amp not produce sound unless the input and output are patched together
A typical stereo receiver / amp consists of switching low level input signals (CD, DVD, Phono, DAT, etc.), processing them and then output to the amplifier (low level) input for amplification to levels needed to drive speakers. The low level signals would barely be audible via an earphone, so they need to be boosted significantly in order to drive speakers.
Some amps provide jumpers to insert into the phono jacks on the rear of the amp to bridge the processed low level output signals into the low level amplifier input. You could install a Y cable here to feed two amplifiers - or - connect a tape recorder's "REC L+R" to the low level output and the "PLAY L+R" to the low level amp input so that you'd hear the actual audio as it had been recorded on the tape.
If you remove the jumpers (or tape recorder if used instead), there is no way for the low level audio to get into the amp's low level inputs for amplification.
Feb 24, 2015 | Audio Players & Recorders
Electric shock from an unplugged Nintendo wii - how is this possible
It was probably just static electricity. Sometimes the body build up static electricity by just walking on a carpet or from friction of the clothes being worn. He then got the shock when he somehow grounded himself.
Jan 19, 2013 | Nintendo Wii Video Game Consoles & Games
The faceplate display on my JVC stereo has a lot of dust inside it. Can I disassemble the faceplate and clean the inside? Everything works great, it is just more of an irritant!!
Yes, you can take the faceplate apart and use air pressure or a photo lens brush to remove the dust. You probably won't get all of it off as the dust is attracted to that area due to the static build up. You can try using an antistatic spray on the lens to try to dampen down the issue longer.
Nov 29, 2012 | JVC KD-S890 CD Player
A CD remains in the drive and the door will no open to remove it.
Chances are that the CD is not located properly and is jamming the doorTry gently inserting a thin blade at the top of the door to hold the CD down ( a credit card might work but don't push it all the way in!). At the same time prise gently underneath the CD tray with a small screwdriver whilst pressing the eject button.
If that doesn't work you will need to remove the case from the receiver. Before doing so unplug from mains electricity. Once you have the casing off briefly touch something metal (like bare metal part on heating radiator) to lose any static electricity in your body before touching anything inside the device.
Feb 25, 2011 | Audio Players & Recorders
Dim LED display
As far as I recall, there is no adjustment. Typically the display area can be cleaned as smoke and dust collects on the plate. Remove the front panel and clean the inner surface of the plate. You may find that sufficient to resolve the problem. If not, then check the power supply for 5V and 12V. If the supply is low, the unit will still work properly, but the display can be dim.
Dan
Jan 22, 2010 | Nakamichi Audio Players & Recorders
Turn unit on, display flashes for 1 second, then
It could be that the amp's overload protection circuit is being triggered by a feedback loop or other problem, such as a shorted or bad cable connection.
Turn off the power and unplug the receiver. Look for problems, starting with shorted speaker wires or cables. Then make sure the receiver's not still hot (wait 5-10 minutes to let it cool), and remove obstructions or anything blocking the top vents. If you didn't find anything, think again about what the problem might be (and maybe taking it to a repair shop) before going to the next step.
Plug it back in and power up again. Before the delayed speaker amp output clicks on, immediately change the Source selector to something unconnected, and turn the Volume DOWN just in case there's a feedback loop (hum/squeal/noise that can overload things and cause the protection circuit to trip again). If you can see the display, go to a low level (around -50dB should be fine). Then carefully switch back to the problem source -- if that's the problem, switch off again immediately and re-check all of the cable connections at both ends, the receiver and the source component.
Make sure you don't have a feedback loop due to a recording device feeding back a signal. All VCRs and CD/DVD-recorders should be hooked up to the VCR, DVR or TAPE/CD-R "IN/OUT" jacks with IN being connected to the cables marked OUT on the deck and vice versa. (That confuses even us experienced guys sometimes!)
Also, no MONITOR video or audio outputs should be connected to the recording decks, nor should the TV outputs be fed back to the recorders. The same goes for the digital IN/OUT jacks for CD recorders; use only the same number IN as OUT for each component (For example, Optical IN/OUT #4 and #5 are the two digital IN/OUT pairs on the Denon AVR-380X series.)
Nov 05, 2009 | Yamaha HTR-5850 Receiver
Electric shock when leaving car
Although it's possible that there is an electrical problem in your car, it's more likely that the shock you're feeling is naturally occurring static electricity.
If your tires were replaced as part of the front end repairs, it's possible this is the cause. Cars naturally build up static electricity from rolling around on rubber tires (the same thing that happens when you rub a balloon on your hair). This static used to get dissipated through the tires to the ground -- however, new, fuel-saving tires with lower rolling resistance are made of a rubber compound that doesn't dissipate static electricity as well as the old stuff. (The price we pay for better gas mileage.)
The static builds up in your car, and then gets discharged through you when you get out of the car and complete a circuit between the car and the ground through your body.
One solution is to attach a ground strap to your car. You can buy these rubber strips from most auto parts stores. One end attaches to a metal part on your car. The other end drags on the ground and dissipates static through it, rather than through you.
Sep 13, 2009 | iLO XM-MP3-CD Car Stereo
Rth230b honeywell display screen faint
Mike, The static electrical spark probably 'zapped' the Rth230b Honeywell Display unit. If you have already tried removing the power (batteries) from the unit and after waiting several minutes; reapply the power (batteries). If the problems remain unchanged, then it is time to replace the Display unit with a new one. The static electricity problem is problematic and the only way to prevent the same problem from recurring is to discharge yourself before touching the Honeywell Display. As you walk across the room which (probably has carpet), causes the static electricity to build up on your body and then discharges itself through the Display unit when you make contact with the Display unit. You might try coming to a complete stop and attempt to discharge the static charge on your body by touching the wall first with one hand for a second before touching the Display unit with the other hand. Naturally, cold weather with low humidity makes the static electricity worse. Hopes this helps you. Henry
Feb 04, 2009 | Honeywell Programmable Thermostat Heater
After static shock, keypad on fax machine is not working...everything else ok
Most office machines are properly grounded and don't suffer from static problems as severe as this. The machine is not repairable. Before you replace the machine, make sure that your electrical outlets are properly grounded. Then buy a line conditioner that will protect against this.
Nov 30, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Will not record
the classic cdr201 will not record it will go to wait and return to cd status(blank cd etc) there is no led display of sound during this operation you can hear the audio for brief couple of seconds before it goes back to cd mode
Nov 28, 2007 | Classic Electronics CDR201 CD Recorder
JVC DR-MV5S DVD Recorder/VCR Logo
93 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
