Question about Qwestar MVP360 Car DVD Player
QK-DVDM1 need mini din 9 pin monitor only
I have a mobile dvd player, it's fine, but I need two monitors which connect by mini din 9 pin socket. Does anyone know how I can get two monitors. Maker Qwestar; which I believe are not in business anymore product # QK-DVDM1.
I also have a monitor for a qwestar dvd player. email me at onlyforward4me@yahoo.com
Posted on Oct 01, 2007
I just happen to own a monitor for a qwestar dvd player. for more info contact me at www.wattderek@gmail.com
Posted on Jul 25, 2007
SOURCE:
Can not get the DVD player to record to our new LCD TV. Worked fine with the older CRT model. It will play OK. Do I need an upconcertter to make this work?
What kind of connection (wire) are you using to connect the DVD player to the TV? Is it composite (RCA, yellow), component (3X RCA, blue, red, green), S-video (Mini-DIN, like a computer keyboard or mouse connector), DVI (Like a wider computer monitor connector), HDMI (Wider and thinner but like a USB connector)?
Apr 15, 2008 | Televison & Video
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
How do i wire my tv to dvd
At the rear or side of the PC there should be either or both of a 15 Pin DIN Plug, HDMI socket. or a Yellow RCA or 4 -7 pin DIN. Now IF these are present then YES you can connect to a TV. Now some TV's have a connector a DB15 MALE, so that the cable from the PC to the TV, is DB15. this plugs in directly, with appropriate DB15 cable. This, however, will ONLY take the VIDEO to the TV, Audio is delivered via the "Audio Out" Jack on PC, and Plugged into the AV Sockets on the TV, with a dual cored coaxial cable, they are Red & White. Some PC's also have a Yellow RCA Connector, OR a 4 -7 Pin DIN Socket, that requires a Special Adapter Cable (That generally came with the unit, and are colored and marked as to output) to use, for Video/Audio Out to TV. This signal is Composite or SVHS Video & Stereo Out. This connects up TO the TV's Composite/SVHS input Jacks and the Red & White Audio IN, RCA Jacks, &/or DIN SVHS socket.
First you need to know if your PC can output to a TV. Then you need to get the adapter & cables that connect the PC to the TV. Then you need the correct TV drivers installed for your video card. When they are all installed, you need to "Enable" that Monitors, the TV's, Desktop. You need to set either a "Cloned" display or "Spanned, Extended Desktop". Go to "Display Settings" Now ensure the TV/Monitor connected has the correct input/output display settings. Adjust the screens resolution via the resoloution "Slider", it is best to start with, 800x600 32 bit color. or even lower. and once working OK, THEN increase to max resolution, your TV can handle, find out from manual. Once it is all connected up. It should all just work great. Now, from then on, &, to get it to work every-time, the process is. Turn everything OFF. Connect the leads between PC & TV, Turn the TV, ON. Then, startup the PC up. It should "Detect" that it has TWO "Monitors" ie: One Monitor & One TV/Monitor, & you should see your desktop appear after a bit. Now you have screen 1 & screens 2. Now, if you are using "Cloned" mode, then whatever is displayed on the Master monitor, will be displayed on the TV. If you used Spanned, mode, in this mode, however, you will have to."Drag" the Video window, over to the TV, and it is though, you have one "Big Desktop". Now IF using Nvidia or ATI then BOTH of those have thier OWN, Control Panel, this, all then can make it all a lot easier to do it. So I would suggest that this method be used. But if you get stuck, or just want to do it by hand, then the the "By Hand" method is the only way.There is a great program called MultiMon, this allows great control over dual displays, and is well worth installing.
Feb 14, 2010 | Sony DVP-NS575P DVD Player
I want to install a sony dvd player to my curtis flat screen ty
Feb 14, 2010 | Televison & Video
Power Pin-out?
I have built an adapter cable which allows to use monitor with the power supply of an external hard drive. The image below contains the pin-out for the power connector of the L50A as well as the wiring scheme for the adapter cable.
For users in Germany, here is the list of complete part list with prices:
  1. Universal Power Supply 12V 2A DC and 5V 2A DC, 13.20€
  2. 6-Pin Mini-DIN Male, 0.71€
  3. 6-Pin Mini-DIN Female, 0,71€
  4. 5m 6-Wire Cable, 2.80€
Have fun, Wolfgang.
Nov 27, 2008 | Hyundai ImageQuest L50A 15.1" Flat Panel...
Owner´s manual
i also need the owners manual for a qwestar mvp360 my e mail is bently1954@yahoo.com
Feb 02, 2008 | Qwestar MVP360 Car DVD Player
Monitor to monitor 9 pin. rounded ends cable.
www.18002526123.com or call the number. I found this in the manual. The cables are called EZ View cable (122-004020-208)
Dec 21, 2007 | Durabrand PVS1966 Portable DVD Player
Qwestar MVP360A AC Adapter
Purchase a power supply, this will allow you to plug your car cord into the house. Available at most electronic stores, radioshack is your best bet. Good Luck
Sep 18, 2007 | Qwestar MVP360 Car DVD Player
Qwestar MVP360 Car DVD Player Logo
334 people viewed this question
Top Qwestar Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Qwestar Car Audio and Video Expert? Answer questions, earn points and help others
