Question about Canon CLC 1120 Color Copier
I AM USING CANON CLC 1150 LASER PRINTER, I AM REGULARLY GETTING THE ERROR CODE 02FF XXX
  • andzulisv May 11, 2010
    code eo 20 then the actual #s please
  • khamral BAKSH May 11, 2010
    there is no such code please give the whole error code
I can not communicate with the printer to my computer ...
diagnostic tests interpreted as the network port.
Posted on Jan 09, 2009
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Error code e190 0000
Cause:
· The laser controller PCB is faulty.
· The CPU PCB is faulty.
Timing of detection:
An error has occurred while wiring
data to the laser controller PCB from
the CPU PCB at power-on.
Jan 25, 2011 | Canon CLC 1150 Color Copier
My canon clc 1150 is continously showing e 804 ?
• The operation of a fan (indicated
by detail code) is faulty.
• The CPU PCB is faulty.
• The DC driver PCB is faulty.
0001 The electrical unit fan (FM8)
has stopped to rotate in error.
0002 The IP cooling fan (FM7) has
0003 The exhaust fan (FM2) has
0004 The ozone suction fan (FM5)
0005 The toner suction fan (FM6)
0006 The laser scanner motor
cooling fan (FM4) has
0008 The primary charging
assembly fan (FM3) has
Aug 02, 2010 | Canon CLC 1150 Color Copier
CLC 1150 Color Coiper E020 0142 What does this
Toner feed error, possibly clogged up in a feed tube, or in between hopper and developer.
Will most likely need a service technician to fix.
Dec 04, 2009 | Canon CLC 1150 Color Copier
CLC 1180 gives the error code E804 000B and instructs me to turn the unit off and on again. Once this step is completed, it reoccurs.
E804 0006 The laser scanner motor
There is no 000B in the manual....so I assumed it was a six.
The sub codes possible are 0001, 0002, 0003, 0004, 0005, 0006, 0007 and 0008. They all pertain to cooling fan failures.
Oct 19, 2009 | Canon CLC 1150 Color Copier
E0000 0132 error on Canon CLC 1150
this is the fixing error indication reset it * 2 & 8 simultaneously * Copier>Function> Clear>Err>OK .Restart the Machine
Jun 20, 2009 | Canon CLC 1150 Color Copier
E020 02FF Error
the problem this in tolva of cian
Sep 05, 2008 | Canon CLC 1120 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon CLC 1120 Color Copier Logo
74 people viewed this question
old marine
old marine
