Clarion DB148R CD Player Logo
A
Anonymous Posted on Sep 05, 2012
How to remove Clarion DB148R - Clarion DB148R CD Player
2 Related Answers
Anonymous
  • 227 Answers
  • Posted on Sep 13, 2009
SOURCE: fitted clarion db148r car sterreo(pluged in at
The reason you are loosing all of your presets, clock & eq settings is because the 12volt constant is not hooked up properly. The red wire in the harness needs to be hooked up to 12 volt consant. The yellow wire needs to be hooked up to a ignition source. By taking these two steps, you should have normal operation and preset retention.
Anonymous
  • 239 Answers
  • Posted on Aug 19, 2010
SOURCE: got a clarion db148r car stereo system but no
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate
My DB148r doesn't work at all after I change my battery, the mechanic think I will need a cod or something to start it again. But i lost the manual. Pleas help Karl
There should be no code for this radio. Check all of your fuses and make sure you are getting power to both the red and yellow wires if you can.
Lost manual
The web. Look up Clarion, them look up model, you might have to pay for it, but I bet you will find it
1helpful
How to remove a Clarion AB213R radio-Cassette ?
It depends on the type of Clarion Radio.
There are 2 types of Clarion Keys depending on the size of the removal slots in your radio  ...the older , larger version or the later slim version.
See the difference here
http://www.incaripod.com/Brand/Radio_Removal_Tools
Available on Ebay , local car radio store etc
1helpful
2answers
Interupting music by news bulletins
There should be a button or option for TA. Switch it off to avoid Traffic announcements and news.
1helpful
How do I remove a Clarion DRB4275 head unit??
I am not familiar with this particular model but the majority of Clarion Radios require special flat Clarion Extractor Keys.
see examples here
http://www.nexxia.co.uk/Car_stereo_spares/Extractor_keys/clarion.htm
This site shows how to extract a Clarion from a Peugeot (I expect yours will be similar)
http://www.fitaudio.com/?View=entry&EntryID=56
These are usually  readily available on Ebay or your local Car Radio / Audio Store
See examples on Ebay.... Items 150297896696   and  360091776968
Fitted clarion db148r car sterreo(pluged in at rear) when i take ignition key out stereo switches off and all preset radio stations are lost thanks george
3helpful
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
3helpful
Got a clarion db148r car stereo system but no wiring diagram. can you tell me the colour coding for the wiring?
yellow battery
red accessory
black ground
green left rear +
white fr left +
grey fr right +
blue auto antenna
blue/white rem amp
brown phone mute
pls rate
Clarion DB 148R
what is the pin diagram on the connector (left to right) (top to bottom) 1-15
Top Clarion Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
