Question about Toshiba Satellite A135 Notebook
Wifi switch not hooked up - stuck in off, how can I override swit
Toshiba A135 s4407 had motherboard replaced, (mother-in-laws computer) after one year (she never checked wifi) both Wifi switch and volume control never hooked up. Wifi is now in "off" mode. Is there a switch on the motherboard or somewhere else that can be triggered to make the Wifi active or "on"? Tried Fn-F8, but no luck. Tried reinstalling drivers and taking out card and reinstalling - no luck. It seems like they replaced the motherboard with a variant that doesn't include the switches....
Thank you for your help
Pete
    Scholar:
  • 108 Answers
Did you check to see if the wifi was properly plugged in?
Usually this happens after they replace the motherboards or anything else that makes them unplug things.
I would check to make sure it's plugged in and check the wifi card if it don't plug in and make sure it's compatible.
Happy Holiday
Posted on Dec 25, 2008
Toshiba a135-s4407 quit charging when pluged in, replaced battery and charger is putting out 17 volt 4.75amp
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This model Toshiba may have a power socket that plugs onto the motherboard.
This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Dec 21, 2010 | Toshiba Satellite A135-S4407 Notebook
I have a Toshiba A135-S4407. No power
The problem might be from your Processor or probably change the memory module once the problem persist then your processor is the problem and later restart your system ok
Feb 20, 2010 | Toshiba Satellite A135-S4407 Notebook
No response from Toshiba Satellite A135-S4407
Yes, there is a very good chance your motherboard is bad. If you haven't already, please remove one of your two memory chips from the memory bank ( bottom of the laptop ), and try powering up again. Sometimes a bad or loose memory chip can cause a no post issue. If you're still having the same problem, then the only other piece of hardware in your laptop aside from the motherboard that can cause "no video" would be the cpu. Requires a complete tear down of laptop and a known good cpu to test. However, from my personal experiences the A100 series motherboards are notorious for having motherboard problems so it's most likely the motherboard. I can repair your laptop at a great price. Email for info : 586techtools@gmail.com
Mar 07, 2009 | Toshiba Satellite A135-S4407 Notebook
Cannot connect to internet
Check the hardware using the device manager to see if there is an issue with the drivers. You can hold the windows key and press pause break and device manager should show up. Look for any ! ? or other marks on the list.
Mar 25, 2017 | Toshiba Satellite A135-S4407 PC Notebook
Fogot password
u need reload the voice that is the best or if u try any third party software u could not get any warenty
Jan 31, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshibba laptop a135-s2276 ,my mother bords smd chip does not work so display of screen does not appear
The problem is well known witht this model Toshiba - the problem is the fan stops working and then hence shuts down to prevent overheating - it does not take long once the laptop is hot. Without replacing the fan just reboot the laptop until you hear the fan start again on reboot.
Oct 15, 2008 | Intel Motherboard
Toshiba Satellite A135 Notebook Logo
313 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
