Question about Car Audio & Video
Won't play with lights on
Everything works except when we turn on the lights at night. The blue power light is on but not enough power to run the player I guess. I've seen a yellow wire needs to be hooked directly to battery. If that's what is needed, how do I do that?
XO1945xt
Simply run a wire from the battery to the Yellow wire; that is what i did as i needed my own designated wire. On the oter hand the should already be a wire in the dashboard that is connected to the battery directly. All you need to do is find it and connect it (tip is my SUV it is the Black and Red wire that is conected directly to the battery, if it is the same for yours, just connect it) (tip 2 - you can use a one of those voltage testers to find the right wire; I forgot the name of it but that is what I used.
Posted on Apr 23, 2009
You probably have the ground wire hooked to the illumination wire for the car. it will act as a ground when the lights are turned off
Posted on Dec 26, 2008
Crosley CR711
it sounds like the switch that indicates witch item gets power is gone,
Mar 16, 2014 | Crosley Audio Players & Recorders
No dash lights when headlights are turned on. Everything works fine on my vehicle EXCEPT today the panel lights don't work. Turn signals, hazard blinker, oil gauge, rpm gauge, speedometer, drive shift...
there is a regulator for the display brightness, you may have it turn'd down or it has stopped working;. it controls the brightness at which the dash lights are. usually has a speedo sign on it. goes up and down. it works with the main light and is conecter to them on the same lighting board if it has gone then a new light swtch control switch will be needed.
Oct 13, 2013 | 2001 Chrysler Town & Country
Blikers only work with running lights off
You have the tail light you just installed wired wrong or if the new tail light is a LED tail light your looking at the LED's possibly not drawing enough power to make the flasher work. change the flasher to a LED specific one.
Nov 14, 2012 | 2001 Yamaha YZF-R6
HTC Vivid won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | HTC Vivid
Key turns on but no click or start, Radio works lights work but key turns hard. No solinoid click and doesn't start.
check battery and connections first starting requires 300 plus amps lights about 50 so lights work but not enough to start try jump and if starts take to parts store and have then test battery
Jul 06, 2009 | 1998 Dodge Durango
Constint blue light
It means WiiConnect24 is on and you have a message. To turn off WiiConnect24 when you are finished playing the Wii, press and hold the power button until the light truns to red.
Jan 30, 2009 | Nintendo Wii Console
Radio, dome lights and EVIC power problem
I found a paritally blown fuse. When the fuse blew metal pieces ended up partially making contact. After replacing the fuse everything worked great.
Jan 07, 2009 | 1994 Jeep Grand Cherokee
Electrical / Lights / Gages
Pull instrument/ cluster panel and re-melt cold solder joints where circuit board connects to dash connectors. Get them hot enough to turn them bright silver, usually 3-5 seconds each pin.
Good Luck!
Jun 24, 2008 | 1996 Dodge Neon
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Car Audio & Video Logo
111 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
