Question about Canon EOS Elan 7e 35mm SLR Camera
Canon Elan rewinds prematurely?? Help!
I own a Canon Elan II. The problem I'm having is that sometimes the camera will rewind a new roll of film after only 2 or 3 photos are taken. Any ideas on what is causing this?
Im having the same problem-- have you had any luck with this? If so any advice would be greatly appreciated!
Posted on Mar 03, 2010
The camera back button requires power to operate and as the electronics seem to be fried button pushing doesn't open the door. So is there a manual access way? thanks
I had a Canon Elan IIe and I don't recall having to have electronics to open the camera back.
Make sure you have a battery in it, turn it on look at the LCD panel and see if it has film in it.
If so you should be able to push the "mid roll" film rewind button located on the back left side it shows a film canister icon. Once the film has rewound into the canister release the back with the mechanical latch found on the left side (while facing the back of the camera) just push it down and the back will pop open. Those cameras are pretty darn good and the only thing I've seen friy the electronics is using an "old" type flash on the hot shoe and that takes the flash circuit board and melts the thing. I'd expect the camera battery is dead and you can't rewind the film back into the canister.
Nov 08, 2010 | Canon EOS Elan IIE 35mm SLR Camera
My Canon AE-1 Program will not rewind. I shot the whole roll, rewound a little, and then accidentally opened the back cover. The counter reset to S, and the rewind crank just unscrews when I try to...
I think you have already ruined the film except the frames that are rewind back to the film cartridge.
You can take the film out from the camera, push in the rewind button at the bottom, pull out the film from the film take up reel.
On the film cartridge, turn on the long tube in the middle clockwise to wind all the film back into the cartridge.
If you had the back opened briefly, do manual film rewinding in the dark room.
May 21, 2010 | Canon EOS-AE-1 35mm SLR Camera
My Canon EAS Film Rewind Knob is rolling my new film back into the cassette instead of into the camera...please help.
That's what the rewind knob is all about: It will allow you to rewind the film back into the cassette to avoid it to be exposed to the light and therefore losing your pictures.
When loading the film you must insert the film into the receiving spool by hand while the camera back is open. Make sure to advance the start enough so that the spool will 'stick' to the film.
Dec 19, 2009 | Canon EOS-AE-1 35mm SLR Camera
I may have loaded film roll that has already been taken?
Usually when you finish exposing a roll of film, you rewind it until you are sure it is all wound into the cassette. There is a change in the sound as the end of the roll leaves the camera. An exposed roll would have no film sticking out of the cassette. A new unexposed roll will have a bit of film sticking out of the cassette to pull across the ack to the take up roll.
May 26, 2009 | Canon Elph LT APS Point and Shoot Camera
Film rolls back automaticaly
The camera shouldn't be doing this, assuming you're using 36 exposure (or 24 exposure) film. You may want to set a custom function to prevent automatic rewind -- you would have to rewind the film yourself by pressing the rewind button.
To do this:
1. Under the palm grip, press the 'CF' (custom function) button.
2. Use the main dial to select 'F1' in the LCD. It should show a '0' below the 'F1'.
3. Press the 'CF' button to change the '0' to a '1'.
4. Press the shutter button half way to save the change and exit the custom function setting mode.
If you want to stop the rewind with the film leader still exposed (film doesn't rewind entirely into the cannister), use the same steps but set custom function 'F2' to a value of '1'.
Mar 17, 2009 | Canon EOS-1N RS 35mm SLR Camera
Auto rewind problem
There are 2 things that can cause that problem. Many times it is caused by the user pulling too much film out of the film cartridge and laying it across the film plane, causing it to bunch up on the take-up roller when the camera back is closed.
Make sure the film tip extends no further than the orange indicator in the back of the camera.
If that is not the cause, there is probably a defect in the clutch that flips back and forth each time the camera winds the film. Sometimes they bind up and cause the camera to go into the rewind mode early. It would need to be looked at by a qualified camera technician to determine if that is the problem.
CameraRepairs
Aug 09, 2008 | Canon EOS Elan IIE 35mm SLR Camera
Rewinding nearly completed roll of film
You can do this by setting the command dial on the left side to the last position turning it clockwise. off,p,tv,av,m,a-dep,ISO, rewind. A second button must be pushed at the lower left rear of the display, the smaller button
Jan 11, 2008 | Canon EOS Rebel G-II 35mm SLR Camera
Film Rewind
check the mechanism inside the film compartment, it may have a broken rewinding gear, if there's nothing broken clean the contact point inside the film compartment, use cotton buds and alcohol or fluid.
Aug 26, 2007 | Canon EOS-30 35mm SLR Camera
Auto rewind going crazy
clean the contact terminals inside the film compartment. Your camera has an abnormal autorewind switch detection.
Jan 09, 2007 | Minolta Maxxum 7 / Dynax 7 35mm SLR Camera
Canon EOS Elan 7e 35mm SLR Camera Logo
121 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
